B 5141-0
B 5141-0
    TURCK(上海乐利)
B 5141-0 数据手册
TURCK Industrial Connectivity Products 3 and 4-Wire picofast ® Field Wireable Connectors, Standard • Female Connectors • IEC IP 67 Protection Drawing Part Number Application B 5131-0 Mates with 3-pin threaded cordsets and receptacles B 5141-0 PBT, Black Accepts 3-5 mm cable diameter Solder terminals, accepts up to 24 AWG conductors 85°C 30 VAC/ 36 VDC, 3.0 A Mates with 4-pin threaded cordsets and receptacles B 5133-0 PBT, Black Accepts 3-5 mm cable diameter Screw terminals, accepts up to 22 AWG conductors 85°C 60 VAC/ 75 VDC, 4 A Mates with 3-pin threaded cordsets and receptacles B 5143-0 C49 Specifications PBT, Black Accepts 3-5 mm cable diameter Solder terminals, accepts up to 24 AWG conductors 85°C 60 VAC/ 75 VDC, 4 A PBT, Black Accepts 3-5 mm cable diameter Screw terminals, accepts up to 22 AWG conductors 85°C 60 VAC/ 75 VDC, 4 A Pinout Mates with 4-pin threaded cordsets and receptacles B 5231-0 PBT, Black Accepts 3-5 mm cable diameter Solder terminals, accepts up to 24 AWG conductors 85°C 60 VAC/ 75 VDC, 4 A Mates with 3-pin threaded cordsets and receptacles B 5241-0 PBT, Black Accepts 3-5 mm cable diameter Solder terminals, accepts up to 24 AWG conductors 85°C 30 VAC/ 36 VDC, 3.0 A Mates with 4-pin threaded cordsets and receptacles TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-7769 Fax: (763) 553-0708 www.turck.com
B 5141-0 价格&库存
很抱歉,暂时无法提供与“B 5141-0”相匹配的价格&库存,您可以联系我们找货
