BI2-EG08K-AP6X-V1131
    TURCK(上海乐利)
    TURCK - BI2-EG08K-AP6X-V1131 - SENSOR CONNECTOR, M8, PLUG, 3POS, CABLE
BI2-EG08K-AP6X-V1131 数据手册
BI2-EG08K-AP6X-V1131 Inductive Sensor – With Increased Switching Distance Features ■M8 × 1 threaded barrel ■Stainless steel, 1.4305 (AISI 303) ■Large sensing range ■DC 3-wire, 10…30 VDC ■NO contact, PNP output ■M8 x 1 male connector Wiring diagram Technical data BI2-EG08K-AP6X-V1131 ID 4669450 General data   Rated switching distance 2 mm Mounting conditions Flush Secured operating distance ≤ (0.81 × Sn) mm Repeat accuracy ≤ 2 % of full scale Temperature drift ≤ ±10 % Hysteresis 20  % Electrical data   Operating voltage 10…30  VDC Residual ripple ≤ 10 % Uss DC rated operational current ≤ 150 mA No-load current 15  mA Residual current ≤ 0.1 mA Isolation test voltage ≤ 0.5 kV Short-circuit protection yes / Cyclic Voltage drop at Ie ≤ 1.8 V Wire breakage/Reverse polarity protection yes / Complete Output function 3-wire, NO contact, PNP Switching frequency 3 kHz Mechanical data   Design Threaded barrel, M8 × 1 Dimensions 31  mm Housing material Stainless steel, 1.4305 (AISI 303) Active area material Plastic, PA6.6 Functional principle Inductive sensors detect metal objects contactless and wear-free. For this, they use a high-frequency electromagnetic AC field that interacts with the target. Inductive sensors generate this field via an RLC circuit with a ferrite coil. Hans Turck GmbH & Co. KG | 45466 Mülheim an der Ruhr, Germany | T +49 208 4952-0 | F +49 208 4952-264 | more@turck.com | www.turck.com 1|3 BI2-EG08K-AP6X-V1131| 20-04-2022 06-37 | Technical modifications reserved Type Technical data Max. tightening torque of housing nut 5 Nm Electrical connection Connector, M8 × 1 Environmental conditions   Ambient temperature -25…+70  °C Vibration resistance 55 Hz (1 mm) Shock resistance 30 g (11 ms) Protection class IP67 MTTF 2283  years acc. to SN 29500 (Ed. 99) 40 °C Switching state LED, Yellow Mounting instructions Distance D 2xB Distance W 3 x Sn Distance T 3xB Distance S 1.5 x B Distance G 6 x Sn Diameter active area B Ø 8 mm Accessories BST-08B 6947210 Mounting clamp for threaded barrel sensors, with dead-stop; material: PA6 QM-08 6945100 Quick-mount bracket with deadstop, chrome-plated brass, male thread M12 x 1. Note: The switching distance of proximity switches may be reduced through the use of quickmount brackets. Hans Turck GmbH & Co. KG | 45466 Mülheim an der Ruhr, Germany | T +49 208 4952-0 | F +49 208 4952-264 | more@turck.com | www.turck.com 2|3 BI2-EG08K-AP6X-V1131| 20-04-2022 06-37 | Technical modifications reserved Mounting instructions/Description MW-08 6945008 BSS-08 6901322 Mounting bracket for threaded barrel sensors; material: Stainless steel A2 1.4301 (AISI 304) MBS80 Mounting clamp for smooth and threaded barrel sensors; material: Polypropylene 69479 Mounting clamp for smooth barrel sensors; mounting block material: Anodized aluminum Accessories Type ID PKGV3M-2/TEL 6625385 Connection cable, female M8, straight, 3-pin, stainless steel coupling nut, cable length: 2 m, sheath material: PVC, black; cULus approval; other cable lengths and qualities available, see www.turck.com BI2-EG08K-AP6X-V1131| 20-04-2022 06-37 | Technical modifications reserved Dimension drawing Hans Turck GmbH & Co. KG | 45466 Mülheim an der Ruhr, Germany | T +49 208 4952-0 | F +49 208 4952-264 | more@turck.com | www.turck.com 3|3
BI2-EG08K-AP6X-V1131 价格&库存
很抱歉,暂时无法提供与“BI2-EG08K-AP6X-V1131”相匹配的价格&库存,您可以联系我们找货
