BI8U-Q10-AP6X2-V1131
    TURCK(上海乐利)
    TURCK - BI8U-Q10-AP6X2-V1131 - INDUCTIVE SENSOR, 8MM, M8 X 1
BI8U-Q10-AP6X2-V1131 数据手册
Inductive sensor BI8U-Q10-AP6X2-V1131 ■ Rectangular, height 10.8 mm ■ Active face on top ■ Plastic, PBT-GF30-V0 ■ Factor 1 for all metals ■ Resistant to magnetic fields ■ Extended temperature range ■ High switching frequency ■ DC 3-wire, 10…30 VDC ■ NO contact, PNP output ■ M8 x 1 male connector Wiring Diagram BI8U-Q10-AP6X2-V1131 1662002 S1662002 Rated switching distance Sn Mounting conditions Assured switching distance Repeatability Temperature drift Hysteresis Ambient temperature 8 mm Flush ð (0,81 x Sn) mm ð 2 % of full scale ð ± 10 % ð ± 15 %, ð -25 °C v ï +70 °C 3…15 % -30…+85 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Isolation test voltage Short-circuit protection Voltage drop at Ie Wire breakage / Reverse polarity protection Output function Protective insulation Switching frequency 10…30VDC ð 10 % Uss ð 200 mA ð 15 mA ð 0.1 mA ð 0.5 kV yes/ cyclic ð 1.8 V yes/ complete 3-wire, NO contact, PNP ÷ 0.25 kHz Design Dimensions Housing material Electrical connection Vibration resistance Shock resistance Protection class MTTF Rectangular, Q10 42 x 25 x 10.8 mm Plastic, PBT-GF30-V0 Connector, M8 x 1 55 Hz (1 mm) 30 g (11 ms) IP67 874 years acc. to SN 29500 (Ed. 99) 40 °C Power-on indication Switching state LED green LED yellow Functional principle Inductive sensors detect metal objects contactless and wear-free. uprox® Factor 1 sensors have significant advantages due to their patented ferrite-coreless multicoil system. They detect all metals at the same large switching distance and are resistant to magnetic fields. Edition • 2016-12-20T19:50:12+01:00 Type designation Ident-No. Ident-No (TUSA) 1/3 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Inductive sensor BI8U-Q10-AP6X2-V1131 2xB Distance W 3 x Sn Distance S 1xB Distance G 6 x Sn Width of the active face B 25 mm Edition • 2016-12-20T19:50:12+01:00 Distance D 2/3 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com
BI8U-Q10-AP6X2-V1131 价格&库存
很抱歉,暂时无法提供与“BI8U-Q10-AP6X2-V1131”相匹配的价格&库存,您可以联系我们找货
