BC10-QF5.5-RN6X2
BC10-QF5.5-RN6X2
    TURCK(上海乐利)
    TURCK - BC10-QF5.5-RN6X2 - CAPACITIVE SENSOR, 10MM, 10VDC-30VDC
BC10-QF5.5-RN6X2 数据手册
Capacitive sensor BC10-QF5.5-RN6X2/S250 ■ Rectangular, height 5.5mm ■ Active face on top ■ Plastic, PP ■ Fixed settings ■ DC 3-wire, 10…30 VDC ■ NC contact, NPN output ■ Cable connection Wiring Diagram Type designation Ident-No. Ident-No (TUSA) BC10-QF5.5-RN6X2/S250 2620132 S2620132 Rated switching distance (flush) Rated switching distance (non-flush) Secured operating distance Hysteresis Temperature drift Repeat accuracy Ambient temperature 10 mm 10 mm ð (0.72 x Sn) mm 2…20 % type 20 % ð 2 % of full scale -25…+70 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Switching frequency Isolation test voltage Output function Short-circuit protection Voltage drop at Ie Wire breakage/Reverse polarity protection 10…30 VDC ð 10 % Uss ð 200 mA ð 15 mA ð 0.1 mA 0.1 kHz ð 0.5 kV 3-wire, NC contact, NPN yes/ Cyclic ð 1.8 V yes/ Complete Approvals UL Design Dimensions Housing material Active area material Electrical connection Cable quality Cable cross section Rectangular, QF5.5 54 x 20.3 x 5.5 mm Plastic, PP Plastic, PP Cable Ø 3, LifYY-11Y, PUR, 2 Vibration resistance Shock resistance Protection class MTTF 3 x 0.14 mm 55 Hz (1 mm) 30 g (11 ms) IP67 1080 years acc. to SN 29500 (Ed. 99) 40 °C Power-on indication Switching state LED green LED yellow Functional principle Capacitive proximity switches are designed for non-contact and wear-free detection of electrically conductive as well as non-conductive metal objects. Edition • 2017-09-15T06:05:47+02:00 2 1/2 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Capacitive sensor BC10-QF5.5-RN6X2/S250 Distance D 40 mm Distance W 30 mm Distance S 30 mm Distance G 60 mm Diameter active area B Ø 20 mm The given minimum distances have been checked against the standard switching distance. Should the sensitivity of the sensors be changed via potentiometer, the data sheet specifications no longer Edition • 2017-09-15T06:05:47+02:00 apply. 2/2 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com
BC10-QF5.5-RN6X2 价格&库存
很抱歉,暂时无法提供与“BC10-QF5.5-RN6X2”相匹配的价格&库存,您可以联系我们找货
