BI10U-M30-AP6X-H1141
    TURCK(上海乐利)
    TURCK - BI10U-M30-AP6X-H1141 - INDUCTIVE PROXIMITY SENSOR
BI10U-M30-AP6X-H1141 数据手册
Housing Style 30 mm - Embeddable, eurofast ® Connection Part Number ID Number Sen s Ran ing ge (mm ) Inductive Sensors Features Bi10-M30-AD4X-H1141 T4417500 Bi12-M30-AD4X-H1141 T4417041 Bi10U-M30-AD4X-H1144 M4405072 Bi10-M30-AN6X-H1141 T4617600 Bi10U-EM30-AN6X-H1141 M1636350 Uprox 10 Bi10U-EM30H-AN6X2-H1141 M1636407 Uprox, Stoneface 10 Bi10U-EM30H-AN6X2-H1141/S1589 M1636490 weldguard ®, Uprox 10 Bi10U-M30-AN6X-H1141 M1636150 Uprox 10 Bi15-M30-AN6X-H1141 T4618600 12 Extended Range 10 2-Wire DC 10 15 Bi15U-M30-AN6X-H1141 Extended Range T4618692 Stoneface, Ext. Range M1636736 Uprox+ Bi10-M30-AP6X-H1141 T4617500 10 Bi10U-EM30-AP6X-H1141 M1636340 Uprox 10 Bi10U-EM30H-AP6X2-H1141/S1589 M1636491 weldguard, Uprox 10 Bi10U-M30-AP6X-H1141 M1636140 Uprox 10 Bi10U-M30-AP6X2-H1141 M1636145 Uprox 10 Bi15-M30-AP6X-H1141 T4618500 Extended Range 15 Bi15-EM30H-AP6X-H1141 Bi15-EM30H-AP6X-H1141/S1589 T4618592 Stoneface, Ext. Range T4618593 weldguard 15 Bi15U-EM30-AP6X-H1141 M1636733 15 Bi15-EM30H-AN6X-H1141 Output 10 3-Wire DC NPN 15 15 15 3-Wire DC PNP Stainless steel 30 mm - Embeddable, eurofast ® Connection Bi15U-M30-AP6X-H1141 M1636732 Bi15-EM30H-AP6X-H1141/S1610 T4618589 15 Weld/armorguard 15 3-Wire DC PNP 30 mm - Embeddable, eurofast ® Connection Bi10-M30-VN4X-H1141 T1571600 Comp. Outputs 10 Bi10U-M30-VN4X-H1141 M1582352 Uprox, Comp. Outputs 10 Bi15-M30-VN4X-H1141 T4570711 Comp. Outputs 15 Bi10-M30-VP4X-H1141 T1561600 Comp. Outputs 10 Bi10U-M30-VP4X-H1141 M1582253 Uprox, Comp. Outputs 10 Bi15-M30-VP4X-H1141 T4570710 Comp. Outputs 15 Bi10-M30-Y1X-H1141 M4020200 10 4-Wire DC NPN 4-Wire DC PNP 2-Wire DC For detailed sensor specifications see Section M. Normally Closed versions available upon request, consult factory. C145 B1008 www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 Industrial Automation 10-30 VDC 10-30 VDC # Wir in Dia g gra m Ma ti Cor n g dse t Pow er L ED Ou tpu t LE D usi ng Fac e n tio tec 500 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.2T-* 1 500 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.2T-* 1 1000 ≤100 -30 to +85 IP 68 CPB LCP N/A YE RK 4T-* 2 500 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4T-* 3 2000 ≤200 -30 to +85 IP 68 SS PA 12 N/A YE RKV 4T-* 3 2000 ≤200 -30 to +85 IP 68 SS SF GN YE RKV 4T-* 3 2000 ≤200 -30 to +85 IP 68 SS WG GN YE RKC 4T-*/S1587 3 2000 ≤200 -30 to +85 IP 67 CPB PA 12 N/A YE RK 4T-* 3 300 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4T-* 3 300 ≤200 -25 to +70 IP 67 SS SF N/A YE RKC 4T-*/S1587 3 750 ≤200 -30 to +85 IP 68 CPB LCP N/A YE RK 4T-* 3 500 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4T-* 4 2000 ≤200 -30 to +85 IP 68 SS PA 12 N/A YE RKV 4T-* 4 2000 ≤200 -30 to +85 IP 68 SS WG GN YE RKC 4T-*/S1587 4 2000 ≤200 -30 to +85 IP 67 CPB PA 12 N/A YE RK 4T-* 4 2000 ≤200 -30 to +85 IP 67 CPB PA 12 GN YE RK 4T-* 4 300 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4T-* 4 300 ≤200 -25 to +70 IP 67 SS SF N/A YE RKV 4T-* 4 300 ≤200 -25 to +70 IP 67 SS WG N/A YE RKC 4T-*/S1587 4 750 ≤200 -30 to +85 IP 68 SS LCP N/A YE RK 4T-* 4 750 ≤200 -30 to +85 IP 68 CPB LCP N/A YE RK 4T-* 4 300 ≤200 -25 to +70 IP 67 AG WG N/A YE RKC 4T-*/S1587 4 Wiring Diagrams Diagram 1 Diagram 2 Barrels 10-65 VDC Ho Voltage Pro Sw it Fre ching q. ( Hz) Op e Cur ratin ren g t (m A) Op er Tem ating p. ( °C) TURCK mold-on connectors available on all cable sensors. See page M25. Diagram 3 Diagram 4 Diagram 5 Diagram 6 10-30 VDC 10-65 VDC 500 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.4T-* 5 2000 ≤200 -30 to +85 IP 67 CPB PA 12 N/A YE RK 4.4T-* 5 500 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.4T-* 5 500 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.4T-* 6 2000 ≤200 -30 to +85 IP 67 CPB PA 12 N/A YE RK 4.4T-* 6 300 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.4T-* 6 2000 Remote -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.21T-* 7 Diagram 7 10-65 VDC 5-30 VDC * Length in meters. For material descriptions see page M36. www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 B1008 C146
BI10U-M30-AP6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI10U-M30-AP6X-H1141”相匹配的价格&库存,您可以联系我们找货
