BI4U-M12-AP6X-H1141
BI4U-M12-AP6X-H1141
    TURCK(上海乐利)
    TURCK - BI4U-M12-AP6X-H1141 - Inductive Proximity Sensor, uprox®, Cylindrical, Embeddable, M12, 4 mm...
BI4U-M12-AP6X-H1141 数据手册
Inductive sensor BI4U-MT12-AP6X-H1141 ■ Threaded barrel, M12 x 1 ■ Brass, PTFE-coated ■ Factor 1 for all metals ■ Protection class IP68 ■ Resistant to magnetic fields ■ Large switching distance ■ Recessed mountable ■ DC 3-wire, 10…30 VDC ■ NO contact, PNP output ■ M12 x 1 male connector Wiring diagram BI4U-MT12-AP6X-H1141 1634809 Rated switching distance Sn Mounting conditions Assured switching distance Repeatability Temperature drift Hysteresis Ambient temperature 4 mm flush ð (0,81 x Sn) mm ð 2 % of full scale ð ± 10 % ð ± 15 %, ð -25 °C v ï +70 °C 3…15 % -30…+85 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Rated insulation voltage Short-circuit protection Voltage drop at Ie Wire breakage / Reverse polarity protection Output function Protective insulation Switching frequency 10…30VDC ð 10 % Uss ð 200 mA ð 20 mA ð 0.1 mA ð 0.5 kV yes/ cyclic ð 1.8 V yes/ complete 3-wire, NO contact, PNP ÷ 2 kHz Construction Dimensions Housing material Material active area Max. tightening torque housing nut Connection Vibration resistance Shock resistance IP Rating MTTF threaded barrel, M12 x 1 52 mm metal, CuZn, PTFE-coated plastic, LCP, PTFE-coated 7 Nm male, M12 x 1 55 Hz (1 mm) 30 g (11 ms) IP68 874 years acc. to SN 29500 (Ed. 99) 40 °C Switching state LED yellow Functional principle Inductive sensors detect metal objects contactless and wear-free. Due to the patented multi-coil system, uprox®+ sensors have distinct advantages over conventional sensors. They excel in largest switching distances, maximum flexibility and operational reliability as well as efficient standardization. Edition • 2015-10-24T04:48:03+02:00 Type code Ident no. 1/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI4U-MT12-AP6X-H1141 Distance D 24 mm Distance W 3 x Sn Distance T 3xB Distance S 1.5 x B Distance G 6 x Sn Diameter of the active area B Ø 12 mm All flush mountable uprox®+ threaded barrel types are also recessed mountable. Safe operation is ensured if Edition • 2015-10-24T04:48:03+02:00 the sensor is screwed in by half a turn. 2/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI4U-MT12-AP6X-H1141 Accessories Type code Ident no. Description PN-M12 6905309 Impact protection nut for M12x1 threaded barrel devices; ma- Design terial: Stainless steel A2 1.4305 (AISI 303) BST-12B 6947212 Fixing clamp for threaded barrel devices, with dead-stop; material: PA6 BSS-12 6901321 Mounting bracket for smooth and threaded barrel devices; Edition • 2015-10-24T04:48:03+02:00 material: Polypropylene 3/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com
BI4U-M12-AP6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI4U-M12-AP6X-H1141”相匹配的价格&库存,您可以联系我们找货
BI4U-M12-AP6X-H1141
  • 1+671.54670
库存:6
