C10-A10BX/024UC
C10-A10BX/024UC
    TURCK(上海乐利)
    TURCK - C10-A10BX/024UC - POWER RELAY, SPDT, 10A, 24V, SOCKET
C10-A10BX/024UC 数据手册
IRC Interface and General Applications C10-A10 One pole, change-over contact Relay compatible with sockets: S10, S10-M, S10-P, S10-K 10 A 250 V AC1 10 A 30 V DC1 13 A 250 V AC1 0.5 A 110 V DC1 0.2 A 220 V DC1 Contacts Materials: Standard, code 0 Optional, code 8 Optional, code 5 Max. switching current Max. peak inrush current (20 ms) Max. switching voltage Max. AC load (Table 1) Max. DC load (Table 2) Gap 0.5 mm. Electrical Life, ops. x 106 Table 1 AC1 Cos ϕ 0.4 Ops. Coils (Ohms ±10% @ 20°C) Pull-in voltage Drop-out voltage Nominal coil power 10 ≤0.8 x Un ≥0.1 x Un 1.1 VA (AC)/0.7 W (DC) Ω mA VDC Ω mA 24 290 45 12 224 53 48 1,200 23 24 742 32 115 7,300 9.5 48 3,500 13.7 230 28,800 4.7 110 19,900 5.5 VAC 1 AgNi AgNi + 10µ Au AgSnO2 10 A 30 A 250 V 2.5 KVA 0.1 500 1000 1500 2500 Insulation VA Table 2 Max. DC Load 10 Dielectric strength (1 minute): Open contacts Between contact and coil Isolation resistance at 500 V Isolation, IEC 61810-5: 1,000 V 5 KV ≥1 GΩ 4 KV/3 Amps. DC1 L/R 40ms Specifications Operate time + bounce time 10 ms Release time + bounce time 5 ms Ambient temperature -40°C (no ice) to +70°C Mechanical life ops. 10 Mill. AC, 20 Mill. DC relays Electrical life at nominal load ≥100,000 ops. Operating frequency at nominal load 1,200/hour Protection grade IP 40/RT1 Weight avg. 21 g 1 0.1 50 100 150 200 Volts Dimensions - mm Standard Types 1 28.8 2 35.4 3 5 4 20 6 A1 A2 12.5 AC 50 Hz, (60 Hz): 24, 48, 115, (120), 230, (240) X = LED (standard) C10-A10X ......VAC RC suppressor C10-A10R......VAC DC 12, 24, 48, 110 X = LED, no polarity (standard) C10-A10X ..... VDC Options (DC coils) Polarity and free-wheeling diodes C10-A10FX... VDC AC/DC bridge rectifier (24 or 48 V) C10-A10BX .. VDC 4.75 IEC 61810 EN 60947 FASTON .187 www.turck.us • 1-800-544-7769 • Fax: (763) 553-0708 • TURCK Inc. Minneapolis, MN 55441 B1201 51
C10-A10BX/024UC 价格&库存
很抱歉,暂时无法提供与“C10-A10BX/024UC”相匹配的价格&库存,您可以联系我们找货
