FEN20-16DXP
FEN20-16DXP
    TURCK(上海乐利)
    TURCK - FEN20-16DXP - CONTROLLER, 0.10A
FEN20-16DXP 数据手册
Compact IP20 multiprotocol Ethernet I/O module 16 universal digital channels FEN20-16DXP ■ FLC/ARGEE programmable ■ EtherNet/IP™ slave ■ Modbus TCP slave ■ PROFINET slave ■ 2 RJ45 ports for the Ethernet connection ■ Integrated Ethernet switch ■ 10/100 Mbps ■ 16 universal digital channels, DI / DO ■ 24 VDC, PNP ■ Output current: 1.0 A ■ Protection class IP20 Type designation Ident no. FEN20-16DXP 6931089 Number of channels Operating / load voltage Operating current Electrical isolation Supply voltage Power dissipation, typical Voltage supply connection 16 12…30 VDC 100 mA 500 V between the I/O groups and to Ethernet 24 VDC ð 2.4 W pluggable screw terminal strip Inputs Number of channels Input voltage Supply current Switching threshold Low level signal voltage High level signal voltage Low level signal current High level signal current Input delay Max. input current 16 24 VDC 700 mA 10 V / 2 mA < 9 VDC 11…30 VDC < 1.5 mA > 2,5 mA 2.5 ms 6 mA Outputs Number of channels Output voltage Output current per channel Load type Short-circuit protection Edition • 2017-09-21T09:19:02+02:00 System data Transmission rate 16 12…30 VDC at 70 °C: 0.5 A (8 A in total) or 0.75 A (6 A in total); at 50 °C: 0.75 A (12 A in total) or 1 A (8 A in total) resistive, inductive, lamp load yes Addressing modes Ethernet: Connection technology Ethernet Protocol detection Web server Service Interface Device Reset 10/100 Mbps; Full/Half Duplex; Auto Negotiation; Auto Crossing via coded rotary switches 2 x RJ45 sockets automatic 192.168.1.254 (default) Ethernet via Rotary Switch Modbus TCP Addressing Supported function codes Number of TCP connections Input Data Size Input register start address Output Data Size Output register start address Static IP, BOOTP, DHCP FC1, FC2, FC3, FC4, FC5, FC6, FC15, FC16, FC23 6 max. 1 register 0 (0x0000 hex) max. 1 register 2048 (0x0800 hex) 1/5 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Compact IP20 multiprotocol Ethernet I/O module 16 universal digital channels FEN20-16DXP acc. to EtherNet/IP™ specification < 150 ms supported 6 PROFINET Addressing Conformance class MinCycleTime Fast Start-Up (FSU) Diagnostics Topology detection Automatic addressing DCP B (RT) 1 ms < 150 ms acc. to PROFINET alarm handling supported supported Dimensions (W x L x H) Housing material Operating temperature Storage temperature Protection class Approvals 57.1 x 152.2 x 46.7mm glass fiber reinforced polyamide (PA6-GF30) -40 … 70 ºC -40 … 85 ºC IP20 CE, UL, Class I Div. 2 Edition • 2017-09-21T09:19:02+02:00 EtherNet/IP™ Addressing Quick Connect (QC) Device Level Ring (DLR) Number of CIP connections 2/5 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Compact IP20 multiprotocol Ethernet I/O module 16 universal digital channels FEN20-16DXP Terminal assignment Ethernet RJ45 Ethernet Fieldbus cable (example): RJ45S-RJ45S-441-2M (ident no. 6932517) or RJ45-FKSDD-441-0,5M/S2174 (ident no. 6914221) Power Supply and I/O Channels Terminal Connection The internal module electronics and the I/O channels 0 to 7 are supplied via V1. The I/O channels 8 to 13 are supplied via V2. The I/O channels 14 to 15 are supplied via V3. More devices can be supplied with 24 VDC, or rather up to 0.7 A, Edition • 2017-09-21T09:19:02+02:00 via the terminals OUT1+ and VOUT1-. 3/5 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Compact IP20 multiprotocol Ethernet I/O module 16 universal digital channels FEN20-16DXP Module LED Status LED Color Status Description ETH1 / ETH2 Green ON Ethernet Link (100 Mbps) Flashing Ethernet communication (100 Mbps) ON Ethernet Link (10 Mbps) Flashing Ethernet communication (10 Mbps) OFF No Ethernet link ON Active connection to a master Flashing Ready ON IP address conflict or status word is active Flashing Blink/Wink command active OFF Power off Green ON Diagnostics disabled Red ON Short-circuit Green ON Input/Output: Active OFF Input/Output: Inactive yellow BUS Green Red ERR Edition • 2017-09-21T09:19:02+02:00 I/O 0 – I/O 15 4/5 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Compact IP20 multiprotocol Ethernet I/O module 16 universal digital channels FEN20-16DXP Prozessdaten Mapping Modbus TCP Register-Mapping Reg Eingänge (RO) 0x0000 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 DI9 DI8 DI7 DI6 DI5 DI4 DI3 DI2 DI1 DI0 - - - - - - - - Diag - - - - - - - - DI15 DI14 DI13 DI12 DI11 DI10 COM V1 low Status (RO) 0x0001 - FCE - - CFG Diag (RO) 0x0002 - - - - - Bit 0 Warn - - I/O Diag Ausgänge 0x0800 DO15 DO14 DO13 DO12 DO11 DO10 DO9 DO8 I/O Diag (RO) 0xA000 SCO7 SCO6 SCO5 SCO4 SCO3 SCO2 SCO1 SCO0 I/O Diag (RO) 0xA001 DO7 DO6 DO5 DO4 DO3 DO2 DO1 DO0 - - - - - - - IGS (RW) - - - - - - - - SCO15 SCO14 SCO13 SCO12 SCO11 SCO10 SCO9 SCO8 Bit 9 Bit 8 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 - - - - - - - - EtherNet/IP™ Data Mapping INPUT Word 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 - FCE - - CFG COM V1 low Bit 0 Diag Warn 1 DI15 DI14 DI13 DI12 DI11 DI10 DI9 DI8 DI7 DI6 DI5 DI4 DI3 DI2 DI1 2 - - Sched - - - - - - - - - - - - DI0 I/O Diag 3 4 OUTPUT Word Diag SCO7 SCO6 SCO5 SCO4 SCO3 SCO2 SCO1 SCO0 - - - - - - Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 - - - - - - - - - IGS SCO15 SCO14 SCO13 SCO12 SCO11 SCO10 SCO9 SCO8 Bit 9 Bit 8 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 0 - - - - - - - - - - - - - - - Bit 0 - 1 DO15 DO14 DO13 DO12 DO11 DO10 DO9 DO8 DO7 DO6 DO5 DO4 DO3 DO2 DO1 DO0 PROFINET Prozessdaten Byte Eingänge Ausgänge Bit 7 Bit 6 Bit 5 Bit 4 Bit3 Bit 2 Bit 1 Bit 0 0 DI7 DI6 DI5 DI4 DI3 DI2 DI1 DI0 1 DI15 DI14 DI13 DI12 DI11 DI10 DI9 DI8 0 DO7 DO6 DO5 DO4 DO3 DO2 DO1 DO0 1 DO15 DO14 DO13 DO12 DO11 DO10 DO9 DO8 Legende: Digitaler Eingang x COM Kommunikation auf internem Modulbus gestört DOx Digitaler Ausgang x CFG I/O-Konfigurationsfehler IGS Eingangsgruppe - Kurzschluss FCE I/O-ASSISTANT Force Mode aktiv SCOx Kurzschluss Ausgang x I/O Diag I/O-Diagnose erkannt Diag Warn Diagnose an mind. 1 Kanal Sched Diag Herstellerspezifische Diagnose konfiguriert und aktiv V1 low Unterspannung V1 - - Edition • 2017-09-21T09:19:02+02:00 DIx 5/5 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com
FEN20-16DXP 价格&库存
很抱歉,暂时无法提供与“FEN20-16DXP”相匹配的价格&库存,您可以联系我们找货
