C3-A30X/024VDC
C3-A30X/024VDC
    TURCK(上海乐利)
    TURCK - C3-A30X/024VDC - POWER RELAY, 3PDT, 10A, 24VDC, SOCKET
C3-A30X/024VDC 数据手册
MRC 3-Pole, Standard 11-Pin Plug-In Relay C3-A30 General purpose Three pole, change-over contacts Relay compatible with sockets: S3-B, S3-S, S3-MP, S3-MS, S3-L, S3-PO 10 A 250 V AC1 10 A 30 V DC1 0.5 A 110 V DC1 0.5 A 220 V DC1 Contacts Materials: 4 3 5 7 8 9 2 12 14 22 24 32 34 A1(+) 11 21 31 A2 1 6 11 10 Standard, code 0 Optional, code 8 Optional, code 9 Max. switching current Max. peak inrush current (20 ms) Max. switching voltage Max. AC load (Table 1) Max. DC load (Table 2) Electrical Life, ops. x 106 Table 1 10 Ops. AC1 AC1 ϕ 0.4 Cos AC15 0.1 1 1.5 KVA Table 2 2 2.5 Max. DC Load 10 DC1 DC1 L/R 40ms DC13 Amps. Pull-in voltage Drop-out voltage Nominal coil power ≤0.8 x Un ≥0.1 x Un 2.2 VA (AC)/1.3 W (DC) Ω mA VDC 24 67 92 48 296 46 115 1K7 19 230 7K1 9.5 VAC 1 0.5 Coils (Ohms ±10% @ 20°C) AgNi AgNi + 10µ Au AgNi + 0.2µ Au 10 A 30 A 250 V 2.5 KVA Ω mA 24 433 54 48 1K8 27 110 9K2 12 220 36K1 6 Insulation Dielectric strength (1 minute): Open contacts Between adjacent poles Between contacts and coil Isolation resistance at 500 V Isolation, IEC 61810-1: 1,000 V 2.5 KV 2.5 KV ≥1 GΩ 2.5 KV/3 Specifications Operate time + bounce time 16 ms Release time + bounce time 8 ms Ambient temperature -40°C (no ice) to +70°C Mechanical life ops. 10 Mill. AC, 20 Mill. DC relays Electrical life at nominal load 100,000 ops. Operating frequency at nominal load 1,200/hour Protection degree IP 40/RT1 Weight avg. 90 g 1 0.1 50 100 150 200 Volts Standard Types Dimensions - mm 1 11 A1 9 4 35 3 8 58.5 2 10 A2 AC 50 Hz, (60 Hz): 24, 48, 115, (120), 230, (240) X = LED (standard) C3-A30X ........VAC RC suppressor C3-A30R........VAC 7 6 5 35 DC 24, 48, 110, 220 X = LED, no polarity (standard) Free-wheeling diode Polarity and free-wheeling diodes AC/DC bridge rectifier (24, 48 or 60 V) Lloyd´s www.turck.us • 1-800-544-7769 • Fax: (763) 553-0708 • TURCK Inc. Minneapolis, MN 55441 C3-A30X ....... VDC C3-A30DX .... VDC C3-A30FX..... VDC C3-A30BX .... VDC IEC 61810 EN 60947 B1201 19
C3-A30X/024VDC 价格&库存
很抱歉,暂时无法提供与“C3-A30X/024VDC”相匹配的价格&库存,您可以联系我们找货
