BS 8141-0
BS 8141-0
    TURCK(上海乐利)
    TURCK - BS 8141-0 - SENSOR CONNECTOR, M12, PLUG, 4POS, CABLE
BS 8141-0 数据手册
M12 eurofast® Connectivity 4 and 5-Pin Field Wireable Connectors, Standard Key Housing Style Female Part Number Male Part Number Features Pinout Female BS 8141-0 BS 8241-0 PBT, Black, PG 7 cable gland, accepts 4-6 mm cable diameter, screw terminals, accepts up to 18 AWG conductors, 85 °C, 250 V, 4 A, mates with standard key 4-pin cordsets and receptacles Male BS 8141-0/PG 9 BS 8241-0/PG 9 PBT, Black, PG 9 cable gland, accepts 6-8 mm cable diameter, screw terminals, accepts up to 18 AWG conductors, 85 °C, 250 V, 4 A, mates with standard key 4-pin cordsets and receptacles BS 8151-0/PG 9 BS 8251-0/PG 9 PBT, Black, PG 9 cable gland, accepts 4-8 mm cable diameter, screw terminals, accepts up to 18 AWG conductors, 85 °C, 60 V, 4 A, mates with standard key 5-pin cordsets and receptacles B 81.. B 8141-0 B 8241-0 B 82.. We reserve the right to make technical alterations without prior notice. B 8141-0/PG 9 B 8241-0/PG 9 BS 81.. B 8151-0/PG 9 B 8251-0/PG 9 BS 82.. BM 8151-0/PG 9 PBT, Black, PG 9 cable gland, accepts 6-8 mm cable diameter, screw terminals, accepts up to 18 AWG conductors, metal coupling nut, 85 °C, 60 V, 4 A, mates with standard key 5-pin cordsets and receptacles www.turck.com  • 1-800-544-7769 • Fax: (763) 553-0708 • Turck • Minneapolis, MN 55441 Female Male B2007 D83 Field Wireables yy IEC IP67 Protection
BS 8141-0 价格&库存
很抱歉,暂时无法提供与“BS 8141-0”相匹配的价格&库存,您可以联系我们找货
