C7-A20FX/024VDC
C7-A20FX/024VDC
    TURCK(上海乐利)
    TURCK - C7-A20FX/024VDC - POWER RELAY, DPDT, 10A, 24VDC, SOCKET
C7-A20FX/024VDC 数据手册
QRC 2-Pole, Miniature Power Plug-In Relay C7-A20 General purpose Two pole, change-over contacts Relay compatible with sockets: S7-M, S7-L, S7-P, S7-PO, S7-PI 10 A 250 V AC1 10 A 30 V DC1 0.5 A 110 V DC1 0.2 A 220 V DC1 Contacts Materials: Table 1 1 3 2 4 7 12 14 22 24 A1(+) 11 21 A2 5 6 8 Standard, code 0 Optional, code 8 Optional, code 9 Max. switching current Max. peak inrush current (20 ms) Max. switching voltage Max. AC load (Table 1) Max. DC load (Table 2) Electrical Life, ops. x 106 10 Ops. AC1 Cos 0.4 Coils (Ohms ±10% @ 20°C) 24 48 115 230 1 ≤0.8 x Un ≥0.1 x Un 1.2 VA (AC)/1 W (DC) Pull-in voltage Drop-out voltage Nominal coil power Ω VAC 174 686 4K3 18K6 AgNi AgNi + 10µ Au AgNi + 0.2µ Au 10 A 30 A 250 V 2.5 KVA mA VDC 50 25 10.4 5.2 12 24 48 110 Ω 148 594 2k3 11K4 mA 85 43 21 11 0.1 0.5 1 1.5 KVA Table 2 2 2.5 Max. DC Load 10 Amps. DC1 DC1 L/R 40ms DC13 150 1,000 V 2.5 KV 2.5 KV ≥1 GΩ 2.5 KV/3 Operate time + bounce time 16 ms Release time + bounce time 8 ms Ambient temperature -40°C (no ice) to +70°C Mechanical life ops. 10 Mill. AC, 20 Mill. DC relays Electrical life at nominal load ≥100,000 ops. Operating frequency at nominal load 1,200/hour Protection degree IP 40/RT1 Weight avg. 43 g 0.1 100 Dielectric strength (1 minute): Open contacts Between adjacent poles Between contacts and coil Isolation resistance at 500 V Isolation, IEC 61810-5: Specifications 1 50 Insulation 200 Volts Dimensions - mm Standard Types 1 2 3 5 4 6 7 A 8 B 21 AC 50 Hz, (60 Hz): 24, 48, 72, 115, (120), 230, (240) X = LED (standard) C7-A20X ........VAC DC 12, 24, 48, 72, 110, X = LED, no polarity (standard) Free-wheeling diode Polarity and free-wheeling diodes AC/DC bridge rectifier (24, 48 or 60 V) C7-A20X ....... VDC C7-A20DX .... VDC C7-A20FX..... VDC C7-A20BX .... VDC 4.75 Lloyd´s FASTON .187 www.turck.us • 1-800-544-7769 • Fax: (763) 553-0708 • TURCK Inc. Minneapolis, MN 55441 IEC 61810 EN 60947 B1201 39
C7-A20FX/024VDC 价格&库存
很抱歉,暂时无法提供与“C7-A20FX/024VDC”相匹配的价格&库存,您可以联系我们找货
