C9-A41FX/012VDC
C9-A41FX/012VDC
    TURCK(上海乐利)
    TURCK - C9-A41FX/012VDC - RELAY, 4PDT, 250VAC, 30VDC, 5A
C9-A41FX/012VDC 数据手册
QRC Miniature 4-Pole Plug-In Relay C9-A41 General purpose Four pole, change-over contacts Relay compatible with sockets: S9-M, S9-L, S9-P, S9-PO 5A 5A 250 V AC1 30 V DC1 0.2 A 110 V DC1 Contacts Materials: 1 5 2 6 3 7 Standard, code 1 Optional, code 2 Max. switching current Max. peak inrush current (2.5 ms) Max. switching voltage Max. AC load (Table 1) Max. DC load (Table 2) 13 4 8 12 14 22 24 32 34 42 44 A1(+) 11 21 31 41 A2 9 10 11 12 14 Electrical Life, ops. x 106 Table 1 10 24 48 115 230 1 ≤0.8 x Un ≥0.1 x Un 1.2 VA (AC)/1 W (DC) Pull-in voltage Drop-out voltage Nominal coil power Ω VAC Res Ops. Coils (Ohms ±10% @ 20°C) 174 686 4K3 18K6 AgNi + 0.2µAu AgNi + 10µAu 5A 15 A 250 V 1250 KVA mA VDC 50 25 10.4 5.2 12 24 48 110 Ω 148 594 2K3 11K4 mA 85 43 21 11 0.1 0 400 800 Insulation 1200 VA Table 2 Max. DC Load 10 Amps. Res 0.1 75 125 Volts 200 175 Dimensions - mm Operate time + bounce time 10 ms Release time + bounce time 6 ms Ambient temperature -40°C (no ice) to +70°C Mechanical life ops. 10 Mill. AC, 20 Mill. DC relays Electrical life at nominal load ≥100,000 ops. Operating frequency at nominal load 1,200/hour Protection degree IP 40/RT1 Weight avg. 43 g Standard Types 28 28 37.5 1,000 V 2 KV 2.5 KV ≥1 GΩ 2.5 KV Specifications 1 50 Dielectric strength (1 minute): Open contacts Between adjacent poles Between contacts and coil Isolation resistance at 500 V Isolation, IEC 61810-5: 1 3 24 5678 910 1112 1 2 3 4 5 9 6 10 7 11 8 12 13 13 14 14 21 21 AC 50 Hz, (60 Hz): 24, 48, 72, 115, (120), 230, (240) X = LED (standard) C9-A41X ........VAC DC 12, 24, 48, 72, 110 X = LED, no polarity (standard) Free-wheeling diode Polarity and free-wheeling diodes AC/DC bridge rectifier (24, 48 or 60 V) C9-A41X ....... VDC C9-A41DX .... VDC C9-A41FX..... VDC C9-A41BX .... VDC 2.6 IEC 61810 EN 60947 FASTON .102 48 B1201 www.turck.us • 1-800-544-7769 • Fax: (763) 553-0708 • TURCK Inc. Minneapolis, MN 55441
C9-A41FX/012VDC 价格&库存
很抱歉,暂时无法提供与“C9-A41FX/012VDC”相匹配的价格&库存,您可以联系我们找货
