BI 5-Q08-AN6X2-V1131
    TURCK(上海乐利)
    TURCK - BI 5-Q08-AN6X2-V1131 - Inductive Proximity Sensor
BI 5-Q08-AN6X2-V1131 数据手册
Housing Style - Rectangular 8.0 mm - Embeddable, Potted-In Cable Part Number ID Number Bi 8U-Q08-AN6X2 S1662007 Features Em bed dab le Sen sin Ran g ge (mm ) Inductive Rectangular Sensors Output 8 3-Wire DC NPN Bi 8U-Q08-AP6X2 S1662006 8 3-Wire DC PNP 8.0 mm - Embeddable, Potted-In Cable Bi 5-Q08-AD4X/S34 S4414550 Weld-field • 5 Immune 2-Wire DC Bi 5U-Q08-AN6X2 S1608911 Uprox • 5 Bi 7-Q08-AN6X2 S1601620 Ext. Range • 7 Bi 5U-Q08-AP6X2 S1608901 Uprox • 5 Bi 7-Q08-AP6X2 S1601600 Ext. Range • 7 Bi 5-Q08-VN6X2 S1600200 Comp. Outputs • 5 Bi 7-Q08-VN6X2 S1600920 Ext. Range • 7 Bi 5-Q08-VP6X2 S1600100 Comp. Outputs • 5 Bi 7-Q08-VP6X2 S1600900 Ext. Range • 7 Bi 5-Q08-Y1X S4054000 • 5 3-Wire DC NPN 3-Wire DC PNP 4-Wire DC NPN 4-Wire DC PNP 2-Wire NAMUR For detailed sensor specifications see Section M. Normally Closed versions available upon request, consult factory. B15 B1008 www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 Industrial Automation # Wir in Dia g gra m Cab l /Ja e Len cke gth t Pow er L ED Ou tpu t LE D usi ng Ho Fro n Fac t Cap / e n tio tec Pro Sw it Fre ching q. ( Hz) Op e Cur ratin ren g t (m A) Op er Tem ating p. ( °C) Voltage TURCK mold-on connectors available on all cable sensors. See page M25. 1000 ≤200 -30 to +85 IP 68 Zinc PA12 GN YE 2M/PUR 2 1000 ≤200 -30 to +85 IP 68 Zinc PA12 GN YE 2M/PUR 3 Wiring Diagrams Diagram 1 10-30 VDC Rectangular Diagram 2 10-30 VDC Diagram 3 50 ≤100 -25 to +70 IP 67 Zinc PA 12 N/A YE 2M/PUR 1 10-65 VDC Diagram 4 10-30 VDC 250 ≤200 -30 to +85 IP 67 Zinc PA 12 GN YE 2M/PUR 2 500 ≤200 -25 to +70 IP 67 Zinc PA 12 GN YE 2M/PUR 2 250 ≤200 -30 to +85 IP 67 Zinc PA 12 GN YE 2M/PUR 3 500 ≤200 -25 to +70 IP 67 Zinc PA 12 GN YE 2M/PUR 3 1000 ≤200 -25 to +70 IP 67 Zinc PA 12 GN YE PUR 4 500 ≤200 -25 to +70 IP 67 Zinc PA 12 GN YE PUR 4 1000 ≤200 -25 to +70 IP 67 Zinc PA 12 GN YE 2M/PUR 5 500 ≤200 -25 to +70 IP 67 Zinc PA 12 GN YE 2M/PUR 5 1000 Remote -25 to +70 IP 67 Zinc PA 12 N/A YE 2M/PUR 6 Diagram 5 10-30 VDC 10-30 VDC 10-30 VDC Diagram 6 5-30 VDC For material descriptions see page M36. www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 B1008 B16
BI 5-Q08-AN6X2-V1131 价格&库存
很抱歉,暂时无法提供与“BI 5-Q08-AN6X2-V1131”相匹配的价格&库存,您可以联系我们找货
