BI1-EH04-AP6X
BI1-EH04-AP6X
    TURCK(上海乐利)
    TURCK - BI1-EH04-AP6X - INDUCTIVE PROXIMITY SENSOR
BI1-EH04-AP6X 数据手册
Inductive sensor BI1-EH04-AP6X ■ Smooth barrel, Ø 4 mm ■ Stainless steel, 1.4427 SO ■ DC 3-wire, 10…30 VDC ■ NO contact, PNP output ■ Cable connection Wiring diagram Type code Ident no. BI1-EH04-AP6X 4609540 Rated operating distance Sn Mounting condition Assured switching distance Repeatability Temperature drift Hysteresis Ambient temperature 1 mm flush ð (0,81 x Sn) mm ð 2 % of full scale ð ± 10 % 3…15 % -25…+70 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Rated insulation voltage Short-circuit protection Voltage drop at Ie Wire breakage / Reverse polarity protection Output function Switching frequency 10…30VDC ð 10 % Uss ð 100 mA ð 15 mA ð 0.1 mA ð 0.5 kV yes/ cyclic ð 1.8 V yes/ complete 3-wire, NO contact, PNP 3 kHz Construction Dimensions Housing material Material active area End cap Connection Cable quality Cable cross section smooth barrel, 4 mm 30 mm stainless steel, 1.4427 SO plastic, PA Plastic, PA12 cable 3 mm, LifY-11Y, PUR, 2m Vibration resistance Shock resistance Protection class MTTF 3 x 0.14 mm 55 Hz (1 mm) 30 g (11 ms) IP67 2283 years acc. to SN 29500 (Ed. 99) 40 °C Switching state LED yellow Functional principle Inductive sensors detect metal objects contactless and wear-free. For this, they use a high-frequency electromagnetic AC field that interacts with the target. Inductive sensors generate this field via an RLC circuit with a ferrite coil. We offer special versions for temperatures of -60 °C up to +250 °C. Edition • 2014-10-24T14:11:34+02:00 2 1/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI1-EH04-AP6X 2xB Distance W 3 x Sn Distance T 3xB Distance S 1.5 x B Distance G 6 x Sn Diameter of the active area B Ø 4 mm Edition • 2014-10-24T14:11:34+02:00 Distance D 2/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI1-EH04-AP6X Accessories Type code Ident no. Description BS 540 69475 Fixing clamp; material mounting block: Anodized aluminium; Design clamp sleeve: Steel 69477 Fixing clamp; material mounting block: Anodized aluminium Edition • 2014-10-24T14:11:34+02:00 MBS40 3/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com
BI1-EH04-AP6X 价格&库存
很抱歉,暂时无法提供与“BI1-EH04-AP6X”相匹配的价格&库存,您可以联系我们找货
