BI1.5-EG08-AP6X-H1341
    TURCK(上海乐利)
    TURCK - BI1.5-EG08-AP6X-H1341 - INDUCTIVE PROXIMITY SENSOR
BI1.5-EG08-AP6X-H1341 数据手册
Housing Style 8 mm - Embeddable, Miniature Threaded, eurofast ® Quick Disconnect 8 mm - Embeddable, Miniature Threaded, eurofast Quick Disconnect Part Number ID Number Bi 2-EG08K-AG41X-H1341 S4562011 Sen s Ran ing ge (mm ) Inductive Sensors Features Short Barrel 2 Bi 2-EG08K-AG41X-H1341/S1589 S4562090 weldguard ® 2 Bi 2-EGT08K-AG41X-H1341 S4602543 SS, PTFE Coated 2 Bi 2-EGT08K-AG41X-H1341/S1589 S4602599 SS, PTFE, weldguard 2 Bi 1.5-EG08K-AN6X-H1341 S4669150 Short Barrel 1.5 Bi 2-EG08K-AN6X-H1341 S4669560 Short Barrel 2 Bi 1.5-EG08K-AP6X-H1341 S4669050 Short Barrel 1.5 Bi 2-EG08K-AP6X-H1341 S4669460 Short Barrel 2 Bi 2-EG08K-AP6X-H1341/S1589 S4669486 weldguard 2 Bi 1.5-EG08K-Y1-H1341 S1003620 Short Barrel 1.5 Bi 1.5-EG08K-Y1X-H1341 S1003640 Short Barrel 1.5 2 Bi 2-EG08-AG41X-H1341 S4562001 Ext. Range Bi 2-EG08-AG41X-H1341/S1589 S4562095 weldguard Bi 1.5-EG08-AD6X-H1341 S4600203 Bi 2-EGT08-AG41X-H1341/S100 S4602542 Bi 1.5-EG08-AN6X-H1341 S4602360 Bi 1.5-EG08-AN7X-H1341 S4602361 TTL Compatible 1.5 Bi 1.5U-EG08-AN6X-H1341 S4600550 Uprox 1.5 Bi 2-EG08-AN6X-H1341 S4602160 Ext. Range 2 Bi 2-EG08-AN6X-H1341/S1589 S4602182 weldguard 2 Bi 2U-EG08-AN6X-H1341 S4602037 Uprox 2 Bi 2-EGT08-AN6X-H1341/S100 S4602161 SS, PTFE Coated 2 Bi 1.5-EG08-AP6X-H1341 S4602260 Bi 1.5U-EG08-AP6X-H1341 S4600540 Uprox 1.5 Bi 2-EG08-AP6X-H1341 S4602060 Ext. Range 2 Bi 2-EG08-AP6X-H1341/S1589 S4602086 weldguard 2 Bi 2U-EG08-AP6X-H1341 S4602034 Uprox 2 S4600540-1 Uprox/weldguard 1.5 Bi 1.5U-EG08-AP6X-H1341/S1589 Output 2-Wire DC 3-Wire DC NPN 3-Wire DC PNP 2-Wire DC NAMUR 2 1.5 SS, PTFE Coated 2-Wire DC 2 1.5 3-Wire DC NPN 1.5 3-Wire DC PNP Bi 1.5U-EGT08-AP6X-H1341 S4600555 Uprox, SS, PTFE 1.5 Bi 2-EGT08-AP6X-H1341/S100 S4602257 SS, PTFE Coated 2 Bi 2-EGT08-AP6X-H1341/S100/S1589 S4602079 SS, PTFE, weldguard 2 Bi 2-EG08-VN6X-H1341 S4602521 Comp. Outputs 2 Bi 2-EGT08-VN6X-H1341 S4602264 SS, PTFE Coated 2 Bi 2-EGT08-VN6X-H1341/S1589 S4602589 SS, PTFE, weldguard 2 Bi 2-EG08-VP6X-H1341 S4602522 Comp. Outputs 2 4-Wire DC PNP Bi 1.5-EG08-Y1-H1341 S1003502 1.5 2-Wire DC NAMUR 4-Wire DC NPN For detailed sensor specifications see Section M. Normally Closed versions available upon request, consult factory. C19 B1008 www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 Industrial Automation 10-30 VDC 10-30 VDC # Wir in Dia g gra m Ma ti Cor n g dse t Pow er L ED Ou tpu t LE D usi ng Fac e n tio tec 1000 ≤100 -25 to +70 IP 67 SS PA 12 N/A YE RK 4.23T-* 1 1000 ≤100 -25 to +70 IP 67 SS WG N/A YE RK 4.23T-* 1 1000 ≤100 -25 to +70 IP 67 SS TC N/A YE RK 4.23T-* 1000 ≤100 -25 to +70 IP 67 SS TC N/A YE RK 4.23T-* 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE RK 4T-* 3 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE RK 4T-* 3 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE RK 4T-* 4 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE RK 4T-* 4 3000 ≤150 -25 to +70 IP 67 SS WG N/A YE RK 4T-*/S1587 4 Wiring Diagrams Diagram 1 Diagram 2 Barrels 10-65 VDC Ho Voltage Pro Sw it Fre ching q. ( Hz) Op e Cur ratin ren g t (m A) Op er Tem ating p. ( °C) TURCK mold-on connectors available on all cable sensors. See page M25. Diagram 3 5-30 VDC 10-65 VDC 10-30 VDC 10-30 VDC 10-30 VDC 10-30 VDC 5-30 VDC 5000 Remote -25 to +70 IP 67 SS PA 12 N/A N/A RK 4.21T-* 5 5000 Remote -25 to +70 IP 67 SS PA 12 N/A YE RK 4.21T-* 5 1000 ≤100 -25 to +70 IP 67 SS PA 12 N/A YE RK 4.23T-* 1 1000 ≤100 -25 to +70 IP 67 SS WG N/A YE RK 4.23T-* 1 1000 ≤100 -25 to +70 IP 67 SS PA 12 N/A YE RK 4.23T-* 2 1000 ≤100 -25 to +70 IP 67 SS PA 12 N/A YE RK 4.23T-* 1 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE RK 4T-* 3 2000 ≤150 -25 to +70 IP 68 SS PA 12 N/A YE RK 4T-* 3 2000 ≤150 -30 to +85 IP 67 SS PA 12 N/A YE RK 4T-* 3 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE RK 4T-* 3 3000 ≤150 -25 to +70 IP 67 SS WG N/A YE RKG 4T-*/S1587 3 1000 ≤150 -35 to +85 IP 68 SS PA 12 N/A YE RK 4T-* 3 3000 ≤150 -25 to +100 IP 67 TC TC N/A YE RK 4T-* 3 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE RK 4T-* 4 2000 ≤150 -30 to +85 IP 68 SS PA 12 N/A YE RK 4T-* 4 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE RK 4T-* 4 3000 ≤150 -25 to +70 IP 67 SS WG N/A YE RKG 4T-*/S1587 4 1000 ≤150 -35 to +85 IP 68 SS PA 12 N/A YE RK 4T-* 4 2000 ≤150 -30 to +85 IP 67 SS WG N/A YE RK 4T-*/S1587 4 2000 ≤150 -30 to +85 IP 67 TC TC N/A YE RK 4T-* 4 3000 ≤150 -25 to +100 IP 67 TC TC N/A YE RK 4T-* 4 3000 ≤150 -25 to +100 IP 67 TC TC N/A YE RK 4T-*/S1587 4 3000 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE RK 4.4T-* 6 3000 ≤200 -25 to +70 IP 67 SS TC N/A YE RK 4.4T-* 6 3000 ≤200 -25 to +70 IP 67 SS TC N/A YE RK 4.4T-*/S1587 6 3000 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE RK 4.4T-* 7 5000 Remote -25 to +70 IP 67 SS PA 12 N/A N/A RK 4.21T-* 5 Diagram 4 Diagram 5 Diagram 6 Diagram 7 *Length in meters. For material descriptions see page M36. www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 B1008 C20
BI1.5-EG08-AP6X-H1341 价格&库存
很抱歉,暂时无法提供与“BI1.5-EG08-AP6X-H1341”相匹配的价格&库存,您可以联系我们找货
