BI2-EG08-AN6X-V1131
BI2-EG08-AN6X-V1131
    TURCK(上海乐利)
    TURCK - BI2-EG08-AN6X-V1131 - INDUCTIVE PROXIMITY SENSOR
BI2-EG08-AN6X-V1131 数据手册
Housing Style 8 mm - Embeddable, Miniature Threaded, picofast ® Quick Disconnect 8 mm - Embeddable, Miniature Threaded, picofast Quick Disconnect Part Number ID Number Sen s Ran ing ge (mm ) Inductive Sensors Features Bi 1.5-EG08K-AN6X-V1131 S4672540 Short Barrel 1.5 Bi 2-EG08K-AN6X-V1131 S4669550 Short Barrel 2 Bi 1.5-EG08K-AP6X-V1131 S4672440 Short Barrel 1.5 Bi 2-EG08K-AP6X-V1131 S4669450 Short Barrel 2 Bi 2-EG08K-AP6X-V1131/S957* S4669452 Short Barrel 2 Bi 1.5-EG08K-Y1-V1131 S1003630 Short Barrel 1.5 Bi 1.5-EG08-AN6X-V1131 S4602350 Bi 1.5U-EG08-AN6X-V1131 S4600530 Uprox 1.5 Bi 2-EG08-AN6X-V1131 S4602150 Ext. Range 2 Bi 2U-EG08-AN6X-V1131 S4602036 Uprox 2 Bi 1.5-EG08-AP6X-V1131 S4602220 Bi 1.5U-EG08-AP6X-V1131 S4600520 Bi 2-EG08-AP6X-V1131 S4602050 Ext. Range 2 Bi 2-EG08-AP6X-V1131/S1589 S4602050-1 weldguard ® 2 Bi 2-EGT08-AP6X-V1131/S100 S4602263 SS, PTFE 2 Bi 2-EGT08-AP6X-V1131/S100/S1589 S4602072 SS PTFE, 2 Output 3-Wire DC NPN 3-Wire DC PNP 2-Wire DC NAMUR 1.5 3-Wire DC NPN 1.5 1.5 Uprox 3-Wire DC PNP weldguard 8 mm - Embeddable, Miniature Threaded, picofast Quick Disconnect Bi 2U-EG08-AP6X-V1131 S4602033 2 Bi 1.5-EG08-Y1-V1131 S1003530 1.5 Bi 2-G08K-AP6X-V1131 S4672803 Ext. Range, Short 2-Wire DC NAMUR 2 Barrel 3-Wire DC PNP 8 mm - Embeddable, Miniature Threaded, picofast Quick Disconnect Bi 2-G08-AP6X-V1131 S4602002 3-Wire DC PNP *Full flush mounting in steel without reducing 2 mm sensing range. For detailed sensor specifications see Section M. Normally Closed versions available upon request, consult factory. C15 B1008 www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 Industrial Automation 10-30 VDC 5-30 VDC 10-30 VDC 10-30 VDC 5-30 VDC # Wir in Dia g gra m Ma ti Cor n g dse t Pow er L ED Ou tpu t LE D usi ng Fac e n tio tec 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 1 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 1 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 2 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 2 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 2 5000 Remote -25 to +70 IP 67 SS PA 12 N/A N/A PKG 3Z-* 3 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 1 2000 ≤150 -30 to +85 IP 68 SS PA 12 N/A YE PKG 3Z-* 1 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 1 1000 ≤150 -30 to +85 IP 68 SS PA 12 N/A YE PKG 3Z-* 1 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 2 2000 ≤150 -30 to +85 IP 68 SS PA 12 N/A YE PKG 3Z-* 2 3000 ≤150 -25 to +70 IP 67 SS PA 12 N/A YE PKG 3Z-* 2 3000 ≤150 -25 to +70 IP 67 SS WG N/A YE PKG 3M-*/S1587 2 3000 ≤150 -25 to +100 IP 67 SS TC N/A YE PKG 3Z-* 2 3000 ≤150 -25 to +100 IP 67 SS WG N/A YE PKG 3M-*/S1587 2 1000 ≤150 -30 to +85 IP 68 SS PA 12 N/A YE PKG 3Z-* 2 5000 Remote -25 to +70 IP 67 SS PA 12 N/A N/A PKG 3Z-* 3 3000 ≤150 -25 to +70 IP 67 SS PBT N/A YE PKG 3Z-* 2 3000 ≤150 -25 to +70 IP 67 SS N/A YE PKG 3Z-* 2 Wiring Diagrams Diagram 1 Diagram 2 Barrels 10-30 VDC Ho Voltage Pro Sw it Fre ching q. ( Hz) Op e Cur ratin ren g t (m A) Op er Tem ating p. ( °C) TURCK mold-on connectors available on all cable sensors. See page M25. Diagram 3 10-30 VDC 10-30 VDC *Length in meters. For material descriptions see page M36. www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 B1008 C16
BI2-EG08-AN6X-V1131 价格&库存
很抱歉,暂时无法提供与“BI2-EG08-AN6X-V1131”相匹配的价格&库存,您可以联系我们找货
