BI2-G12-AN6X-H1141
BI2-G12-AN6X-H1141
    TURCK(上海乐利)
    TURCK - BI2-G12-AN6X-H1141 - INDUCTIVE PROXIMITY SENSOR
BI2-G12-AN6X-H1141 数据手册
Housing Style Part Number ® 12 mm - Embeddable, picofast Connection Bi 2-G12-AN6X-V1131 Bi 4-G12-AN6X-V1131 Bi 2-G12-AP6X-V1131 Bi 4-G12-AP6X-V1131 12 mm - Nonembeddable, picofast Connection Ni 5-G12-AN6X-V1131 ID Number Features T4635583 T4606597 M1690703 Sen s Ran i n g ge (m m) Inductive Sensors Extended Range 2 4 Extended Range 2 4 T4635721 Output 3-Wire DC NPN 3-Wire DC PNP 5 3-Wire DC NPN Ni 5-G12-AP6X-V1131 T4635690 5 3-Wire DC PNP 12 mm - Embeddable, eurofast ® Connection Bi 2-G12-AN6X-H1141 T4606693 2 3-Wire DC NPN Bi 2-G12-AP6X-H1141 Bi 4-EG12-AP6X-H1141 12 mm - Nonembeddable, eurofast Connection T4606595 T4607091 Ni 5-G12-AN6X-H1141 Ni 5-G12-AN7X-H1141 Ni 8-G12-AN6X-H1141 T4635793 T1714593 T4611383 Ni 5-G12-AP6X-H1141 T4635692 Extended Range 2 4 Extended Range 5 5 8 3-Wire DC PNP 3-Wire DC NPN 5 3-Wire DC PNP Ni 5-G12-Y0-H1141 T1005594 5 2-Wire DC NAMUR For detailed sensor specifications see Section A. Normally Closed versions available upon request, consult factory. C61 TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-PROX Fax: (763) 553-0708 www.turck.com Industrial Automation TURCK mold-on connectors available on all cable sensors. See page A5. 2000 2000 ≤200 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE 2000 2000 ≤200 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE Wi ri Dia ng gra m# Ma ti Co n g rds et Ou tpu t LE D er L ED Pow Fac e Ho usi ng tion tec Pro Op e Temrating p. ( °C) Voltage Sw itc Fre hing q. ( Hz ) Op e C u ratin rre g nt ( mA ) Industrial Automation PKG 3Z-* PKG 3Z-* 1 PKG 3Z-* PKG 3Z-* 2 1 Wiring Diagrams Diagram 1 10-30 VDC 2 2000 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE PKG 3Z-* Barrels Diagram 2 10-30 VDC 1 10-30 VDC Diagram 3 2000 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE PKG 3Z-* 2 2000 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4T-* 3 2000 2000 ≤200 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE IP 67 SS PA 12 N/A YE RK 4T-* RKV 4T-* 4 -25 to +70 2000 2000 2000 ≤200 ≤200 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE RK 4T-* RK 4T-* RK 4T-* 3 -25 to +70 2000 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4T-* 4 2000 Remote -25 to +70 IP 67 CPB PA 12 N/A N/A RK 4.21T-* 5 10-30 VDC Diagram 4 10-30 VDC Diagram 5 4 10-30 VDC 10-30 VDC 3 3 10-30 VDC 5-30 VDC * Length in meters. For material descriptions see page A34. TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-PROX Fax: (763) 553-0708 www.turck.com C62
BI2-G12-AN6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI2-G12-AN6X-H1141”相匹配的价格&库存,您可以联系我们找货
