BI8U-M18-AP6X-H1141
BI8U-M18-AP6X-H1141
    TURCK(上海乐利)
    TURCK - BI8U-M18-AP6X-H1141 - Inductive Proximity Sensor, Cylindrical, Embeddable, Uprox, M18, 8 mm,...
BI8U-M18-AP6X-H1141 数据手册
BI8U-M18-AP6X-H1141 Inductive sensor Features ■ Threaded barrel, M18 x 1 ■ Chrome-plated brass ■ Factor 1 for all metals ■ Protection class IP68 ■ Resistant to magnetic fields ■ Large switching distance ■ Recessed mountable ■ DC 3-wire, 10…30 VDC ■ NO contact, PNP output ■ M12 x 1 male connector Wiring diagram Technical data Type BI8U-M18-AP6X-H1141 ID number 1644731 Rated switching distance 8 mm Mounting conditions Flush Secured operating distance ≤ (0,81 x Sn)  mm Repeat accuracy ≤ 2 % of full scale Temperature drift ≤ ± 10 % ≤ ± 15 %, ≤ ‐25 °C v ≥ +70 °C Hysteresis 3…15 % Ambient temperature -30…+85 °C Operating voltage 10…30 VDC Residual ripple ≤ 10 % Uss DC rated operational current ≤ 200 mA No-load current ≤ 20 mA Residual current ≤ 0.1 mA Isolation test voltage ≤ 0.5 kV Short-circuit protection yes / Cyclic Voltage drop at ≤ 1.8 V Wire breakage/Reverse polarity protection yes / Complete Output function 3-wire, NO contact, PNP Protection class ÷ Switching frequency 1.5 kHz Design Threaded barrel, M18 × 1 Dimensions 52 mm Housing material Metal, CuZn, Chrome-plated Active area material Plastic, LCP Max. tightening torque housing nut 25 Nm Inductive sensors detect metal objects contactless and wear-free. Due to the patented multi-coil system, uprox®+ sensors have distinct advantages over conventional sensors. They excel in largest switching distances, maximum flexibility and operational reliability as well as efficient standardization. Hans Turck GmbH & Co. KG | 45466 Mülheim an der Ruhr, Germany | T +49 208 4952-0 | F +49 208 4952-264 | more@turck.com | www.turck.com 1|3 Technical data Electrical connection Connector, M12 × 1 Vibration resistance 55 Hz (1 mm) Shock resistance 30 g (11 ms) Protection class IP68 MTTF 874 years acc. to SN 29500 (Ed. 99) 40 °C Switching state LED yellow Mounting instructions/Description Distance D 36 mm Distance W 3 x Sn Distance T 3xB Distance S 1.5 x B Distance G 6 x Sn Diameter active area B Ø 18 mm All flush mountable uprox®+ threaded barrel types are also recessed mountable. Safe operation is ensured if the sensor is screwed in by half a turn. Mounting accessories PN-M18 6905310 Protective nut for M18 x 1 threaded barrels; material: Stainless steel A2 1.4305 (AISI 303) BST-18B 6947214 Fixing clamp for threaded barrel devices, with dead-stop; material: PA6 Hans Turck GmbH & Co. KG | 45466 Mülheim an der Ruhr, Germany | T +49 208 4952-0 | F +49 208 4952-264 | more@turck.com | www.turck.com 2|3 QM-18 6945102 MW-18 Quick-mount bracket with dead-stop; material: Chrome-plated brass Male thread M24 x 1.5. Note: The switching distance of proximity switches can be reduced by the use of quick-mount brackets. BSS-18 6945004 Mounting bracket for threaded barrel devices; material: Stainless steel A2 1.4301 (AISI 304) 6901320 Mounting bracket for smooth and threaded barrel devices; material: Polypropylene Wiring accessories Type ID number RKC4T-2/TEL 6625010 Connection cable, female M12, straight, 3pin, cable length: 2 m, sheath material: PVC, black; cULus approval; other cable lengths and qualities available, see www.turck.com Hans Turck GmbH & Co. KG | 45466 Mülheim an der Ruhr, Germany | T +49 208 4952-0 | F +49 208 4952-264 | more@turck.com | www.turck.com 3|3
BI8U-M18-AP6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI8U-M18-AP6X-H1141”相匹配的价格&库存,您可以联系我们找货
BI8U-M18-AP6X-H1141
  • 1+746.69295
库存:19
