BI10U-Q14-AP6X2-V1131
    TURCK(上海乐利)
    TURCK - BI10U-Q14-AP6X2-V1131 - INDUCTIVE SENSOR, 10MM, M8 X 1
BI10U-Q14-AP6X2-V1131 数据手册
Inductive sensor BI10U-Q14-AP6X2-V1131 ■ Rectangular, height 14 mm ■ Active face on top ■ Plastic, PBT-GF30-V0 ■ Factor 1 for all metals ■ Resistant to magnetic fields ■ Extended temperature range ■ High switching frequency ■ DC 3-wire, 10…30 VDC ■ NO contact, PNP output ■ M8 x 1 male connector Wiring Diagram BI10U-Q14-AP6X2-V1131 1608500 Rated switching distance Sn Mounting conditions Secured operating distance Repeat accuracy Temperature drift Hysteresis Ambient temperature 10 mm Flush ð (0,81 x Sn) mm ð 2 % of full scale ð ± 10 % ð ± 15 %, ð -25 °C v ï +70 °C 3…15 % -30…+85 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Isolation test voltage Short-circuit protection Voltage drop at Ie Wire breakage/Reverse polarity protection Output function Switching frequency 10…30 VDC ð 10 % Uss ð 200 mA ð 15 mA ð 0.1 mA ð 0.5 kV yes/ Cyclic ð 1.8 V yes/ Complete 3-wire, NO contact, PNP 0.25 kHz Design Dimensions Housing material Electrical connection Vibration resistance Shock resistance Protection class MTTF Rectangular, Q14 52 x 30 x 14 mm Plastic, PBT-GF30-V0 Connector, M8 × 1 55 Hz (1 mm) 30 g (11 ms) IP67 874 years acc. to SN 29500 (Ed. 99) 40 °C Power-on indication Switching state LED green LED yellow Functional principle Inductive sensors detect metal objects contactless and wear-free. uprox® Factor 1 sensors have significant advantages due to their patented ferrite-coreless multicoil system. They detect all metals at the same large switching distance and are resistant to magnetic fields. Edition • 2017-09-20T12:14:38+02:00 Type designation Ident no. 1/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI10U-Q14-AP6X2-V1131 1.5 x B Distance W 3 x Sn Distance S 1xB Distance G 6 x Sn Width active area B 30 mm Edition • 2017-09-20T12:14:38+02:00 Distance D 2/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI10U-Q14-AP6X2-V1131 Accessories Type code Ident no. Description MW-Q14/Q20 6945006 Mounting bracket for rectangular Q14 or Q20; material VA 1.4301 Wiring accessories Type code Ident no. Description PKG3M-2/TEL 6625058 Connection cable, female M8, straight, 3-pin, cable length: 2 m, sheath material: PVC, black; cULus approval; other cable Edition • 2017-09-20T12:14:38+02:00 lengths and qualities available, see www.turck.com 3/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com
BI10U-Q14-AP6X2-V1131 价格&库存
很抱歉,暂时无法提供与“BI10U-Q14-AP6X2-V1131”相匹配的价格&库存,您可以联系我们找货
