BS 5143-0
BS 5143-0
    TURCK(上海乐利)
    TURCK - BS 5143-0 - SENSOR CONNECTOR, M8, PLUG, 4POS, CABLE
BS 5143-0 数据手册
M8 picofast ® Connectivity 3 and 4-Wire Field Wireable Connectors, Standard • IEC IP67 Protection Housing Style Female Part Number Male Part Number Features Pinout Female B 513(4)1-0 B 5131-0 BS 5131-0 PBT, Black, accepts 3-5 mm cable diameter, solder terminals, accepts up to 24 AWG conductors, 85°C, 60 VAC/ 75 VDC, 4 A, mates with 3-pin threaded cordsets and receptacles Male Female BS 513(4)1-0 B 5141-0 BS 5141-0 PBT, Black, accepts 3-5 mm cable diameter, solder terminals, accepts up to 24 AWG conductors, 85°C, 30 VAC/ 36 VDC, 4.0 A, mates with 4-pin threaded cordsets and receptacles Male Female B 513(4)3-0 B 5133-0 BS 5133-0 PBT, Black, accepts 3-5 mm cable diameter, screw terminals, accepts up to 22 AWG conductors, 85°C, 60 VAC/ 75 VDC, 4 A, mates with 3-pin threaded cordsets and receptacles Male Female BS 513(4)3-0 B 5143-0 C24 B2007 BS 5143-0 www.turck.us · PBT, Black, accepts 3-5 mm cable diameter, screw terminals, accepts up to 22 AWG conductors, 85°C, 60 VAC/ 75 VDC, 4 A, mates with 4-pin threaded cordsets and receptacles 1-800-544-7769 · Fax: (763) 553-0708 · Male TURCK Inc. Minneapolis, MN 55441
BS 5143-0 价格&库存
很抱歉,暂时无法提供与“BS 5143-0”相匹配的价格&库存,您可以联系我们找货
