FKM-FS57-M12
FKM-FS57-M12
    TURCK(上海乐利)
    TURCK - FKM-FS57-M12 - M12, 5-PIN, FEEDTHROUGH, MALE/FEMALE CONNECTOR 99M0418
FKM-FS57-M12 数据手册
FKM-FS57-M12 Accessories for Fieldbus Systems – Wall/panel feed-through Features ■ Type: M12 adapter ■ 5-pin feedthrough male/female connector ■ For use in CAN (DeviceNet™, CANopen) applications ■ Ampacity: 4 A ■ Rated voltage: 150 V ■ Temperature range: -40 °C…+105 °C ■ Protection class: NEMA 1, 3, 4, 6P and IEC IP67 Diagram Type FKM-FS57-M12 Ident. no. 6602223 Connector A Wall Feedthrough/Female Receptacle, M12 × 1, Straight Number of contacts 5 Contacts Brass, CuZn, Gold-plated Contact carriers Plastic, TPU, Blue Connector body Brass, CuZn, Nickel-plated Mounting orientation Front mount Mounting thread M12x1 Mechanical life > 100 Mating cycles Pollution degree 3 Protection class When coupled - IP67, (screwed together) Connector B Male receptacle Fieldbus DeviceNet™ CANopen Rated voltage 150 V Current 4 A Insulation resistance ≥ 108 Ω forward resistance ≤ 5 mΩ Temperature range (static) -40 °C…+105 °C TURCK Inc. | 3000 Campus Drive Minneapolis, MN 55441-2656 | Phone: 763-553-7300 | Application Support: 1-800-544-7769 | Fax 763-553-0708 | www.turck.com FKM-FS57-M12 | 11/09/2019 23-47 | technical changes reserved Technical data 1|1
FKM-FS57-M12 价格&库存
很抱歉,暂时无法提供与“FKM-FS57-M12”相匹配的价格&库存,您可以联系我们找货
