FS 4.5-PCB
FS 4.5-PCB
    TURCK(上海乐利)
    TURCK - FS 4.5-PCB - RECEPTACLE, EUROFAST, PANEL MOUNT
FS 4.5-PCB 数据手册
M12 eurofast ® Connectivity 5 and 6-Wire Receptacles, Front Mount, 1/2-14 NPT Threads • NEMA 1, 3, 4, 6P • IEC IP68 Protection Housing Style Female Part Number Male Part Number Features Pinout FK 4.5-*/14.5/NPT FS 4.5-*/14.5/NPT 1. BN 5x22 AWG, 105°C, 2. WH 250 V, 4 A, mates 3. BU with 5-pin cordsets 4. BK 5. GY Male FK .. 14.5/NPT Female Typical panel cutout is 22.5 mm. FK 4.6-*/14.5/NPT FS 4.6-*/14.5/NPT 6x22 AWG, 105°C, 250 V, 4 A, mates with 6-pin cordsets FS ..14.5/NPT Male 1. 2. 3. 4. 5. 6. BN WH BU BK GY PK Female Typical panel cutout is 22.5 mm. FK 6-*/14.5/NPT FS 6-*/14.5/NPT 6x24 AWG, 105°C, 60 VAC/75 VDC, 2 A, mates with 6-pin cordsets Male * Length in meters. Standard lead length is 0.5 Meters. Consult factory for other lengths. Standard housing material is nickel plated brass "FS.."; "FSV.." indicates stainless steel. To specify PVC jacketed cable, add "/S717" to the end of the part number. www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 B2007 D55 Receptacles Female
FS 4.5-PCB 价格&库存
很抱歉,暂时无法提供与“FS 4.5-PCB”相匹配的价格&库存,您可以联系我们找货
