BI4-M12-AN6X-H1141
BI4-M12-AN6X-H1141
    TURCK(上海乐利)
    TURCK - BI4-M12-AN6X-H1141 - INDUCTIVE PROXIMITY SENSOR
BI4-M12-AN6X-H1141 数据手册
Housing Style Part Number ® 12 mm - Embeddable, eurofast Connection Bi 4-M12K-AP6X-H1141 ID Number T4607082 Features Short Barrel Sen s Ran i n g ge (m m) Inductive Sensors Output 4 3-Wire DC PNP Bi 2-M12K-VP6X-H1141 M1633005 Short Barrel 2 4-Wire DC PNP 12 mm - Embeddable, eurofast Connection Bi 2-M12-AD4X-H1141 Bi 2-M12-AD4X-H1141/S34 Bi 3-M12-AD4X-H1141 T4406500 M4406530 T4405041 Bi Bi Bi Bi Bi Bi Bi 2-EM12-AN6X-H1141 2-M12-AN6X-H1141 3-EM12WD-AN6X-H1141 3U-EM12-AN6X-H1141 3U-M12-AN6X-H1141 3U-M12-AN6X2-H1141 4-M12-AN6X-H1141 T4606601 T4606600 M1634334 M1634350 M1634150 M1634155 T4607100 Bi Bi Bi Bi Bi Bi Bi Bi 2-EM12-AP6X-H1141 2-M12-AP6X-H1141 3-EM12WD-AP6X-H1141 3U-EM12-AP6X-H1141 3U-EM12H-AP6X-H1141 3U-M12-AP6X-H1141 3U-M12-AP6X2-H1141 4-M12-AP6X-H1141 T4606501 T4606500 M1634331 M1634340 M1634312 M1634140 M1634145 T4607000 Weld-field Immune Ext. Range Washdown Uprox Uprox Uprox Extended Range Washdown Uprox Uprox, Stoneface Uprox Uprox Extended Range Comp. Outputs Bi 2-M12-VN6X-H1141 Bi 4-M12-VN6X-H1141 T1643000 T1643200 Ext. Range, Comp. Outputs Bi 2-M12-VP6X-H1141 Bi 4-M12-VP6X-H1141 T1633000 T1633200 Ext. Range, Comp. Outputs Bi 2-EM12-Y0X-H1141 Bi 2-M12-Y1X-H1141 T4010098 M4010200 Comp. Outputs 2 2 3 2 2 3 3 3 3 4 2 2 3 3 3 3 3 4 2 4 2 4 2 2 2-Wire DC 3-Wire DC NPN 3-Wire DC PNP 4-Wire DC NPN 4-Wire DC PNP 2-Wire DC NAMUR For detailed sensor specifications see Section A. Normally Closed versions available upon request, consult factory. C49 TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-PROX Fax: (763) 553-0708 www.turck.com Industrial Automation TURCK mold-on connectors available on all cable sensors. See page A5. Wi ri Dia ng gra m# Ma ti Co n g rds et Ou tpu t LE D er L ED Pow Fac e Ho usi ng tion tec Pro Op e Temrating p. ( °C) Voltage Sw itc Fre hing q. ( Hz ) Op e C u ratin rre g nt ( mA ) Industrial Automation 2000 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4T-* 3 2000 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.4T-* 5 1000 1000 1000 ≤100 ≤100 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE 2000 2000 2000 3000 3000 3000 2000 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +85 IP 68, 69K SS PVDF N/A YE -30 to +85 IP 68 SS PA 12 N/A YE -30 to +85 IP 67 CPB PA 12 N/A YE -30 to +85 IP 67 CPB PA 12 GN YE -25 to +70 IP 67 CPB PA 12 N/A YE 2000 2000 2000 3000 3000 3000 3000 2000 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +85 IP 68, 69K SS PVDF N/A YE -30 to +85 IP 68 SS PA 12 N/A YE -30 to +85 IP 68 SS SF N/A YE -30 to +85 IP 67 CPB PA 12 N/A YE -30 to +85 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE ≤200 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE 10-30 VDC 2000 2000 -25 to +70 IP 67 CPB PA 12 N/A YE 2000 2000 ≤200 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE 10-30 VDC -25 to +70 IP 67 CPB PA 12 N/A YE 5000 5000 Remote Remote -25 to +70 IP 67 SS PA 12 N/A YE 5-30 VDC -25 to +70 IP 67 CPB PA 12 N/A YE Wiring Diagrams Diagram 1 10-30 VDC Diagram 2 10-65 VDC 10-30 VDC 10-30 VDC RK 4.2T-* RK 4.2T-* RK 4.2T-* 1 RKV 4T-* RK 4T-* RK 4.4Z-*/S90 RKV 4T-* RK 4T-* RK 4T-* RK 4T-* 2 RKV 4T-* RK 4T-* RK 4.4Z-*/S90 RKV 4T-* RKG 4T-*/S600 RK 4T-* RK 4T-* RK 4T-* 3 RK 4.4T-* RK 4.4T-* 4 RK 4.4T-* RK 4.4T-* 5 RKV 4.21T-* RK 4.21T-* 6 1 1 Barrels 10-30 VDC Diagram 3 2 2 2 Diagram 4 2 2 2 3 3 Diagram 5 3 3 3 3 3 Diagram 6 4 5 6 * Length in meters. For material descriptions see page A34. TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-PROX Fax: (763) 553-0708 www.turck.com C50
BI4-M12-AN6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI4-M12-AN6X-H1141”相匹配的价格&库存,您可以联系我们找货
