BI5U-Q08-AP6X2
BI5U-Q08-AP6X2
    TURCK(上海乐利)
    TURCK - BI5U-Q08-AP6X2 - 35R9630
BI5U-Q08-AP6X2 数据手册
ñEdition: Hans Turck GmbH & Co.KG ñD-45472 Mülheim an der Ruhr ñWitzlebenstraße 7 ñTel. 0208 4952-0 ñFax 0208 4952-264 ñmore@turck.com ñwww.turck.com Inductive sensor Bi5U-Q08-AP6X2 LED 20 ø 3,4 13 8 3 32 ● rectangular, height 8 mm ● top active face ● metal, die-cast zinc ● factor 1 for all metals ● magnetic field immune ● extended temperature range ● high switching frequency ● 3-wire DC, 10…30 VDC ● normally open, pnp output ● cable connection Wiring diagram Bi5U-Q08-AP6X2 1608901 Rated operating distance Sn Mounting condition Assured sensing range Repeatability Temperature drift Hysteresis Ambient temperature 5 mm flush ð (0,81 x Sn) mm ð 2% ð ± 10 % ð ± 15 %, ð -25 °C v ï +70 °C 3… 15 % -30…+ 85 °C Operating voltage Residual ripple 10… 30VDC ð 10 % Uss DC rated operational current No-load current I0 ð 200 mA ð 15 mA Residual current Rated insulation voltage Short-circuit protection Voltage drop at Ie ð 0.1 mA ð 0.5 kV yes / cyclic ð 1.8V Wire breakage / Reverse polarity protection Output function Insulation class Switching frequency yes / complete 3-wire, normally open, pnp ÷ ð 0.25 kHz Housing Dimensions Housing material Material active face Connection Cable quality Cable cross section: Vibration resistance Shock resistance Degree of protection rectangular, Q08 32 x 20 x 8 mm metal, GD-Zn, black plastic, LCP-GF30, yellow cable Ø 4, LifY-11Y, PUR, 2 m 3 x 0.25mm2 55 Hz (1 mm) 30g (11 ms) IP67 Operating voltage display Display switch state LED green LED yellow pnp BN + BU – BK Functional principle Inductive sensors are designed for wear-free and non-contact detection of metal objects. Due to a ferrite-less 3-coil system, uprox factor 1 sensors have distinct advantages. They detect all metals at the same switching distance, are magnetic field immune and feature large switching distances. ñEdition: • 25.11.2008 Type Ident-No. Hans Turck GmbH & Co.KG ñD-45472 Mülheim an der Ruhr ñWitzlebenstraße 7 ñTel. 0208 4952-0 ñFax 0208 4952-264 ñmore@turck.com ñwww.turck.com ñEdition: Hans Turck GmbH & Co.KG ñD-45472 Mülheim an der Ruhr ñWitzlebenstraße 7 ñTel. 0208 4952-0 ñFax 0208 4952-264 ñmore@turck.com ñwww.turck.com Inductive sensor Bi5U-Q08-AP6X2 Mounting instructions Distance D Distance W Distance G minimum distances 40 мм 15 мм 30 мм Width of the active face B 20 mm W D ñEdition: • 25.11.2008 G Hans Turck GmbH & Co.KG ñD-45472 Mülheim an der Ruhr ñWitzlebenstraße 7 ñTel. 0208 4952-0 ñFax 0208 4952-264 ñmore@turck.com ñwww.turck.com
BI5U-Q08-AP6X2 价格&库存
很抱歉,暂时无法提供与“BI5U-Q08-AP6X2”相匹配的价格&库存,您可以联系我们找货
BI5U-Q08-AP6X2
    • 1+554.57848
    库存:21
