BS 8151-0/PG9
BS 8151-0/PG9
    TURCK(上海乐利)
    TURCK - BS 8151-0/PG9 - SENSOR CONNECTOR, M12, PLUG, 5POS, CABLE
BS 8151-0/PG9 数据手册
TURCK Industrial Connectivity Products 4, 5 and 8-Wire M12 eurofast ® Field Wireable Connectors, Standard and Reverse Key • Straight Male Connectors • IEC IP 67 Protection Drawing D165 B2006 Part Number Housing Specs. Application BS 8141-0 PBT, Black PG 7 cable gland accepts 4-6 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 60 V, 4 A Mates with standard key 4-pin cordsets and receptacles BS 8141-0/PG 9 PBT, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 60 V, 4 A Mates with standard key 4-pin cordsets and receptacles BS 8151-0/PG 9 PBT, Black PG 9 cable gland, accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 60 V, 4 A Mates with standard key 5-pin cordsets and receptacles BS 8157-0/PG 9 PBT, Black PG 9 cable gland, accepts 6-8 mm cable diameter Spring clamp accepts up to 20 AWG conductors 85°C 125 V, 4 A Mates with standard key 5-pin cordsets and receptacles, spring clamp BSWS 8141-0 PBT, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 250 V, 4 A Mates with reverse key 4-pin cordsets and receptacles BSWS 8151-0 PBT, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 125 V, 4 A Mates with reverse key 5-pin cordsets and receptacles BS 8181-0 Nylon, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 30 VAC/75 VDC, 2 A Mates with standard key 8-pin cordsets and receptacles www.turck.us 1-800-544-7769 Fax: (763) 553-0708 Pinout TURCK Inc. Minneapolis, MN 55441
BS 8151-0/PG9 价格&库存
很抱歉,暂时无法提供与“BS 8151-0/PG9”相匹配的价格&库存,您可以联系我们找货
