BC20-CP40-VP4X2
BC20-CP40-VP4X2
    TURCK(上海乐利)
    BC20-CP40-VP4X2
BC20-CP40-VP4X2 数据手册
Capacitive sensor BC20-CP40-VP4X2 ■ Rectangular, height 40 mm ■ 9 sensor head positions ■ Plastic, PBT-GF30-V0 ■ Fine adjustment via potentiometer ■ DC 4-wire, 10…65 VDC ■ Complementary contact, PNP output ■ Terminal chamber Wiring Diagram Type designation Ident no. BC20-CP40-VP4X2 25160 Rated switching distance (flush) Rated switching distance (non-flush) Secured operating distance Hysteresis Temperature drift Repeat accuracy Ambient temperature 20 mm 20 mm ð (0.72 x Sn) mm 2…20 % type 20 % ð 2 % of full scale -25…+70 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Switching frequency Isolation test voltage Output function Short-circuit protection Voltage drop at Ie Wire breakage/Reverse polarity protection 10…65 VDC ð 10 % Uss ð 200 mA ð 15 mA ð 0.1 mA 0.1 kHz ð 0.5 kV 4-wire, Complementary contact, PNP yes/ Cyclic ð 1.8 V yes/ Complete Design Dimensions Housing material Active area material Electrical connection Clamping ability Rectangular, CP40 114 x 40 x 40 mm Plastic, PBT-GF30-V0 Plastic, PBT-GF30-V0, yellow Terminal chamber Vibration resistance Shock resistance Protection class MTTF ð 2.5 mm 55 Hz (1 mm) 30 g (11 ms) IP67 1080 years acc. to SN 29500 (Ed. 99) 40 °C Power-on indication Switching state LED green LED yellow Diameter active area B Ø 40 mm Functional principle Capacitive proximity switches are designed for non-contact and wear-free detection of electrically conductive as well as non-conductive metal objects. Edition • 2017-09-20T13:14:18+02:00 2 1/2 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Capacitive sensor BC20-CP40-VP4X2 Accessories Type code Ident no. Description SG40 69500 Protective housing; housing material: PA (per UL94/V-2); cover: PBT-GF30; for harsh environments; protection degree IP68, 5 m w.g. Adjusting bar JS 025/037 69429 Adjusting bar for rectangular housings CK/CP40; material: VA 1.4301 BSS-CP40 6901318 Mounting bracket for rectangular devices; material: Edition • 2017-09-20T13:14:18+02:00 Polypropylene 2/2 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com
BC20-CP40-VP4X2 价格&库存
很抱歉,暂时无法提供与“BC20-CP40-VP4X2”相匹配的价格&库存,您可以联系我们找货
