BI1.5-EG08-AN6X
BI1.5-EG08-AN6X
    TURCK(上海乐利)
    TURCK - BI1.5-EG08-AN6X - INDUCTIVE PROXIMITY SENSOR
BI1.5-EG08-AN6X 数据手册
Housing Style 8 mm - Embeddable, Miniature Threaded Barrel, Potted-In Cable Part Number ID Number Bi 1.5-EG08-Y1 S1003500 Sen s Ran ing ge (mm ) Inductive Sensors Features Output 1.5 2-Wire DC NAMUR 8 mm - Embeddable, Miniature Threaded Barrel, Potted-In Cable 8 mm - Embeddable, Miniature Threaded Barrel, Potted-In Cable Bi 2-EG08-AG41X S4562000 Bi 2-EG08-AG41X/S1589 S4562088 Bi 1.5-EG08-AN6X S4602340 Bi 1.5U-EG08-AN6X S4600510 Bi 2-EG08-AN6X Bi 2-EG08-AN6X/S1589 2 2 weldguard ® 1.5 Uprox 1.5 S4602140 Ext. Range 2 S4602181 weldguard 2 Bi 2U-EG08-AN6X S4602035 Uprox 2 Bi 1.5-EG08-AN7X S1766110 TTL Compatible 1.5 Bi 1.5-EG08-AP6X S4602240 Bi 1.5U-EG08-AP6X S4600500 Bi 2-EG08-AP6X S4602040 Ext. Range 2 Bi 2-EG08-AP6X/S100 S4602047 High Temp. 100°C 2 Bi 2-EG08-AP6X/S957 S4602008 Flush Mount 2 Bi 2-EG08-AP6X/S1589 S4602085 weldguard 2 Bi 2U-EG08-AP6X S4602032 Uprox 2 Bi 2-EG08-AZ14X S4100001 Bi 2-EG08-VP6X S1604610 Comp. Outputs 2 S4602086-1 armorguard 2 Bi 2-EG08-AP6X/S1610 2-Wire DC 3-Wire DC NPN 1.5 1.5 Uprox 2 3-Wire DC PNP 2-Wire AC/DC 4-Wire DC PNP 3-Wire DC PNP 8 mm - Embeddable, Miniature Threaded Barrel, Potted-In Cable, PTFE Coated Bi 2-EGT08K-AG41X S4602545 SS, PTFE, Short Barrel 2 2-Wire DC 8 mm - Embeddable, Miniature Threaded Barrel, Potted-In Cable, PTFE Coated Bi 2-EGT08-AG41X S4602540 Bi 2-EGT08-AG41X/S1589 S46020003 SS, PTFE, weldguard 2 2-Wire DC Bi 2U-EGT08-AN6X S4602170 Stainless Steel, PTFE 2 3-Wire DC NPN Bi 1.5-EGT08-AP6/S100 S4602256 High Temp. 100°C 1.5 3-Wire DC PNP 2 For detailed sensor specifications see Section M. Normally Closed versions available upon request, consult factory. C39 B1008 www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 Industrial Automation 5000 Remote -25 to +70 Pow er L ED Ou tpu t LE D Cab l / C a e Le n b l e gth Ma t. Wir ing Dia gra m# End Cap usi ng Ho Fac e n tio tec Pro Voltage Op er Tem ating p. ( °C) Sw it Fre ching q. ( Hz) Op e Cur ratin ren g t (m A ) TURCK mold-on connectors available on all cable sensors. See page M25. IP 67 SS PA 12 TROG N/A N/A 2M/PUR 3 PA 12 TROG Wiring Diagrams Diagram 1 5-30 VDC 10-30 VDC 10-30 VDC 20-132 VAC 10-140 VDC 10-30 VDC 1000 ≤100 -25 to +70 IP 67 SS 1000 ≤100 -25 to +70 IP 67 SS 3000 ≤150 -25 to +70 IP 67 2000 ≤150 -30 to +85 IP 68 N/A YE 2M/PUR 4 TROG N/A YE 2M/PUR 4 SS PA 12 TROG N/A YE 2M/PUR 1 SS PA 12 TROG N/A YE 2M/PUR 1 PA 12 TROG 3000 ≤150 -25 to +70 IP 67 SS 3000 ≤150 -25 to +70 IP 67 SS WG WG TROG N/A YE 2M/PUR 1 N/A YE 2M/PUR 1 2000 ≤150 -30 to +85 IP 68 SS PA 12 TROG N/A YE 2M/PUR 1 3000 ≤150 -25 to +70 IP 67 SS PA 12 TROG N/A YE 2M/PUR 1 3000 ≤150 -25 to +70 IP 67 SS PA 12 TROG N/A YE 2M/PUR 2 2000 ≤150 -30 to +85 IP 68 SS PA 12 TROG N/A YE 2M/PUR 2 3000 ≤150 -25 to +70 IP 67 SS PA 12 TROG N/A YE 2M/PUR 2 3000 ≤150 -25 to +100 IP 67 SS PA 12 TROG N/A YE 2M/PUR 2 PA 12 TROG 3000 ≤150 -25 to +70 IP 67 SS 3000 ≤150 -25 to +70 IP 67 SS 2000 ≤150 -30 to +85 IP 68 20 ≤100 -25 to +70 3000 ≤150 3000 N/A YE 2M/PUR 2 TROG N/A YE 2M/PUR 2 SS PA 12 TROG N/A YE 2M/PUR 2 IP 67 SS PA 12 TROG N/A YE 2M/PUR 5 -25 to +70 IP 67 SS PA 12 TROG N/A YE 2M/PUR 6 £150 -25 to +70 IP 67 AG WG TROG N/A YE 2M/PUR 2 1000 £100 -25 to +70 IP 67 TC PA 12 TC N/A YE 2M/PUR 4 1000 ≤100 -25 to +70 IP 67 TC PA 12 TC N/A YE 2M/PUR 4 1000 ≤100 -25 to +70 IP 67 SS WG TC N/A YE 2M/PUR 4 2000 ≤150 -30 to +85 IP 68 SS PA 12 TROG N/A YE 2M/PUR 1 2000 ≤150 -25 to +100 IP 67 TC PA 12 N/A YE 2M/PUR 2 WG Diagram 2 Barrels 10-55 VDC Diagram 3 Diagram 4 Diagram 5 Diagram 6 10-30 VDC 10-55 VDC 10-55 VDC 10-30 VDC 10-30 VDC TC For material descriptions see page M36. www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 B1008 C40
BI1.5-EG08-AN6X 价格&库存
很抱歉,暂时无法提供与“BI1.5-EG08-AN6X”相匹配的价格&库存,您可以联系我们找货
