C2-A20DX/024VDC
C2-A20DX/024VDC
    TURCK(上海乐利)
    TURCK - C2-A20DX/024VDC - POWER RELAY, DPDT, 10A, 24VDC, SOCKET
C2-A20DX/024VDC 数据手册
MRC 2-Pole, Standard 8-Pin Plug-In Relay C2-A20 General purpose Two pole, change-over contacts Relay compatible with sockets: S2-B, S2-S, S2-L, S2-PO 10 A 250 V AC1 10 A 30 V DC1 0.5 A 110 V DC1 0.2 A 220 V DC1 Contacts Materials: Table 1 4 3 5 6 2 12 14 22 24 A1 (+) 11 21 A2 1 8 7 Standard, code 0 Optional, code 8 Optional, code 9 Max. switching current Max. peak inrush current (20 ms) Max. switching voltage Max. AC load (Table 1) Max. DC load (Table 2) Electrical Life, ops. x 106 Coils (Ohms ±10% @ 20°C) Pull-in voltage Drop-out voltage Nominal coil power AgNi AgNi + 10µ Au AgNi + 0.2µ Au 10 A 30 A 250 V 2.5 KVA ≤0.8 x Un ≥0.1 x Un 2.2 VA (AC)/1.3 W (DC) Ω mA VDC 24 67 92 48 296 46 115 1K7 230 7K1 VAC Ω mA 24 433 54 48 1K8 27 19 110 9K2 12 9.5 220 36K1 6 Insulation Table 2 Max. DC Load Dielectric strength (1 minute): Open contacts Between adjacent poles Between contacts and coil Isolation resistance at 500 V Isolation, IEC 61810-5: 1,000 V 2.5 KV 2.5 KV ≥1 GΩ 2.5 KV/3 Specifications Operate time + bounce time 16 ms Release time + bounce time 8 ms Ambient temperature -40°C (no ice) to +70°C Mechanical life ops. 10 Mill. AC, 20 Mill. DC relay Electrical life at nominal load ≥100,000 ops. Operating frequency at nominal load 1,200/hour Protection degree IP 40/RT1 Weight avg. 90 g Standard Types Dimensions - mm 1 8 A1 3 6 58.5 35 2 7 A2 5 4 35 AC 50 Hz, (60 Hz): 24, 48, 115, (120), 230, (240) X = LED (standard) C2-A20X ........VAC RC suppressor C2-A20R........VAC DC 24, 48, 110, 220 X = LED, no polarity (standard) C2-A20X ....... VDC Free-wheeling diode C2-A20DX .... VDC Polarity and free-wheeling diodes C2-A20FX..... VDC AC/DC bridge rectifier (24, 48 or 60 V) C2-A20BX .... VDC Lloyd´s 16 B1201 www.turck.us • 1-800-544-7769 • Fax: (763) 553-0708 IEC 61810 EN 60947 • TURCK Inc. Minneapolis, MN 55441
C2-A20DX/024VDC 价格&库存
很抱歉,暂时无法提供与“C2-A20DX/024VDC”相匹配的价格&库存,您可以联系我们找货
