CT 2-A30/M
CT 2-A30/M
    TURCK(上海乐利)
    TURCK - CT 2-A30/M - OFF-DELAY TIME CUBE, 0.2S-30MIN, 150V
CT 2-A30/M 数据手册
TIME CUBE 8 and 11-Pin, Time Cube The modules CT 2 and CT 3 are electronic timers that are designed to be inserted beween a standard plug-in relay and its socket, enabling the relay to be operated as a timer relay. The CT modules are able to accept any standard 8 or 11-Pin RELECO series C2 or C3 as well as those from any other supplier. The relay coil voltage must be in the range shown for each model. CT 2A CT 3A CT 2B CT 3B CT 2E CT 3E Off delay Blinker On delay The timing starts when S is switched off. The relay drops out at time (t). The relay blinks ON/OFF at time (t) when switch S is closed. First pulse, ON. The timing starts when the switch S is closed. The relay pulls in at the time (t). R R Function B Function A 10 (7) S 2 10 (7) S + 2-A30/S* .......9.5-18 V 2-A30/L ..........20-65 V 2-A30/M .......90-150 V 2-A30/U .....180-265 V CT CT CT CT 3-A30/S* .......9.5-18 V 3-A30/L ..........20-65 V 3-A30/M .......90-150 V 3-A30/U .....180-265 V 10 (7) 2 S t R S t CT CT CT CT Function E S R S ~ R ~ + R S t t t ~ + CT 2-B30/S* ........ 9.5-18 V CT 2-B30/L ........... 20-65 V CT 2-B30/H ........ 90-265 V CT 2-E30/S* ........ 9.5-18 V CT 2-E30/L ........... 20-65 V CT 2-E30/H ........ 90-265 V CT 3-B30/S* ........ 9.5-18 V CT 3-B30/L ........... 20-65 V CT 3-B30/H ........ 90-265 V CT 3-E30/S* ........ 9.5-18 V CT 3-E30/L ........... 20-65 V CT 3-E30/H ........ 90-265 V *All types are for AC/DC except “S” voltage range (only DC) CT2... (8-Pin) and CT3... (11-Pin) types with time range from 0.2 seconds to 30 minutes (range 30) Time Range Setting 84 B1201 Range 30 Dip - Sw Dimensions 7654 32 1 0.2-3 s 6 5 7 4 2-30 s 50 Time accuracy Repetition +0.5%/20 ms Supply voltage 1 ms / volt. Ambient temperature -0.25% / K Reset time (types E, W, B)
CT 2-A30/M 价格&库存
很抱歉,暂时无法提供与“CT 2-A30/M”相匹配的价格&库存,您可以联系我们找货
