BI10-Q14-AD4X 7M
BI10-Q14-AD4X 7M
    TURCK(上海乐利)
    TURCK - BI10-Q14-AD4X 7M - INDUCTIVE SENSOR, 10MM, 10-65VDC
BI10-Q14-AD4X 7M 数据手册
Inductive sensor Bi10-Q14-AD4X 7M ■ Rectangular, height 14 mm ■ Active face on top ■ Plastic, PBT-GF30-V0 ■ DC 2-wire, 10…65 VDC ■ NO contact ■ Cable connection Wiring diagram Type Ident-No. Bi10-Q14-AD4X 7M 4414561 Rated operating distance Sn Mounting condition Assured sensing range Correction factors Repeatability Temperaturdrift Hysteresis Ambient temperature 10 mm flush ð (0,81 x Sn) mm St37 = 1, V2A ~ 0.7, Ms ~ 0.4, Al ~ 0.3 ð2% 10 % 1…15 % -25…+70 °C Operating voltage Residual ripple DC rated operational current Residual current Rated insulation voltage Short-circuit protection Voltage drop at Ie Output function Smallest operating currentIm Switching frequency 10…65VDC ð 10 % Uss ð 100 mA ð 0.6 mA ð 0.5 kV yes/ cyclic ð 5V 2-wire, NO contact, 2-wire ð 3 mA 0.15 kHz Design Dimensions Housing material Connection Cable quality Cable cross section rectangular, Q14 52 x 30 x 14 mm Plastic, PBT-GF30-V0 cable 5.2 mm, LifYY-11Y, PUR, 7 m Vibration resistance Shock resistance Protection class MTTF 2 x 0.5 mm 55 Hz (1 mm) 30 g (11 ms) IP67 2283years acc. to SN 29500 (Ed. 99) 40 °C Switching state LED yellow Functional principle Inductive sensors detect metal objects contactless and wear-free. For this purpose they use a high-frequency electromagnetic AC field that interacts with the target. The sensors hosting a ferrite core coil generate the AC field through an LC resonant circuit. Edition • 2012-05-23T21:37:50+02:00 2 1/3 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com
BI10-Q14-AD4X 7M 价格&库存
很抱歉,暂时无法提供与“BI10-Q14-AD4X 7M”相匹配的价格&库存,您可以联系我们找货
