BI5U-EM18-AP6X-H1141
    TURCK(上海乐利)
    TURCK - BI5U-EM18-AP6X-H1141 - INDUCTIVE SENSOR, 5MM, M18 X 1
BI5U-EM18-AP6X-H1141 数据手册
Inductive sensor BI5U-EM18-AP6X-H1141 ■ Threaded barrel, M18 x 1 ■ Stainless steel, 1.4301 ■ Factor 1 for all metals ■ Protection class IP68 ■ Resistant to magnetic fields ■ Extended temperature range ■ High switching frequency ■ DC 3-wire, 10…30 VDC ■ NO contact, PNP output ■ M12 x 1 male connector Wiring Diagram BI5U-EM18-AP6X-H1141 1635340 Rated switching distance Sn Mounting conditions Secured operating distance Repeat accuracy Temperature drift Hysteresis Ambient temperature 5 mm Flush ð (0,81 x Sn) mm ð 2 % of full scale ð ± 10 % ð ± 15 %, ð -25 °C v ï +70 °C 3…15 % -30…+85 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Isolation test voltage Short-circuit protection Voltage drop at Ie Wire breakage/Reverse polarity protection Output function Protection class Switching frequency 10…30 VDC ð 10 % Uss ð 200 mA ð 20 mA ð 0.1 mA ð 0.5 kV yes/ Cyclic ð 1.8 V yes/ Complete 3-wire, NO contact, PNP ÷ 2.5 kHz Design Dimensions Housing material Active area material Max. tightening torque housing nut Electrical connection Vibration resistance Shock resistance Protection class MTTF Threaded barrel, M18 × 1 52 mm Stainless steel, V2A (1.4301) Plastic, PBT 25 Nm Connector, M12 × 1 55 Hz (1 mm) 30 g (11 ms) IP68 874 years acc. to SN 29500 (Ed. 99) 40 °C Switching state LED yellow Functional principle Inductive sensors detect metal objects contactless and wear-free. uprox® Factor 1 sensors have significant advantages due to their patented ferrite-coreless multicoil system. They detect all metals at the same large switching distance and are resistant to magnetic fields. Edition • 2017-09-20T12:45:55+02:00 Type designation Ident no. 1/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI5U-EM18-AP6X-H1141 2xB Distance W 3 x Sn Distance T 3xB Distance S 1.5 x B Distance G 6 x Sn Diameter active area B Ø 18 mm Edition • 2017-09-20T12:45:55+02:00 Distance D 2/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI5U-EM18-AP6X-H1141 Accessories Type code Ident no. Description MW-18 6945004 Mounting bracket for threaded barrel devices; material: Stainless steel A2 1.4301 (AISI 304) BSS-18 6901320 Mounting bracket for smooth and threaded barrel devices; material: Polypropylene Wiring accessories Type code Ident no. Description RKH4-2/TFE 6935482 Connection cable, M12 connector, female, straight, 3-pin, cable length: 2 m, sheath material: PVC, grey; temperature range: -25…+80 °C (in resting state), 0…+80 °C (in motion); other cable lengths and types available, see www.turck.com RKH4-2/TFG 6934384 Connection cable, M12 connector, female, straight, 3-pin, cable length: 2 m, sheath material: TPE, grey; temperature range: -40…+105 °C (in resting state), -25…+105 °C (in motion); other cable lengths and types available, see Edition • 2017-09-20T12:45:55+02:00 www.turck.com 3/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com
BI5U-EM18-AP6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI5U-EM18-AP6X-H1141”相匹配的价格&库存,您可以联系我们找货
