BI5U-M18-AP6X-H1141
BI5U-M18-AP6X-H1141
    TURCK(上海乐利)
    TURCK - BI5U-M18-AP6X-H1141 - INDUCTIVE PROXIMITY SENSOR
BI5U-M18-AP6X-H1141 数据手册
Housing Style Part Number ® 18 mm - Embeddable eurofast Connection ID Number Features Sen s Ran ing ge (m m) Inductive Sensors Bi 5-M18-AD4X-H1141 Bi 7-M18-AD4X-H1141 T4414500 T4414541 Bi Bi Bi Bi Bi Bi T4614601 T4614600 M1635350 M1635150 M4614534 T4615100 Extended Range 5 5 5 5 7 8 M1901004 Uprox 5 5-EM18-AN6X-H1141 5-M18-AN6X-H1141 5U-EM18-AN6X-H1141 5U-M18-AN6X-H1141 7-EM18WD-AN6X-H1141 8-M18-AN6X-H1141 Bi 5U-M18-ASIX-H1140 Extended Range Uprox Uprox Washdown 5 7 Output 2-Wire DC 3-Wire DC NPN 2-Wire ASI-BUS Bi Bi Bi Bi Bi Bi Bi Bi Bi 5-EM18-AP6X-H1141 5-M18-AP6X-H1141 5U-EM18-AP6X-H1141 5U-M18-AP6X-H1141 7-EM18WD-AP6X-H1141 7-M18WD-AP6X-H1141 8-M18-AP6X-H1141 8-EM18H-AP6X-H1141 8-EM18H-AP6X-H1141/S1589 T4614501 T4614500 M1635340 M1635140 M4614531 M4614529 T4615000 T4615094 T4615099 Uprox Uprox Washdown Washdown Ext. Range Ext. Range weldguard Bi 5-EM18-VN4X-H1141 Bi 5-M18-VN4X-H1141 Bi 8-M18-VN4X-H1141 T4614699 T1571800 T4590702 Comp. Output Bi 5-M18-VP4X-H1141 Bi 8-M18-VP4X-H1141 T1561800 T4590701 Comp. Output Bi 5-M18-Y1X-H1141 M4015200 Comp. Output Ext. Range Ext. Range 5 5 5 5 7 7 8 8 8 5 5 8 5 8 3-Wire DC PNP 4-Wire DC NPN 4-Wire DC PNP 5 2-Wire NAMUR 18 mm - Embeddable eurofast Connection, Stainless Steel Bi 5-EM18FM-AP6X-H1141 M4614539 Stainless Steel Front Cap 5 3-Wire DC PNP For detailed sensor specifications see Section M. Normally Closed versions available upon request, consult factory. D91 TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-7769 Fax: (763) 553-0708 www.turck.com Industrial Automation 10-65 VDC 10-30 VDC 1000 1000 ≤100 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE 1000 1000 2500 2500 1000 500 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -30 to +85 IP 68 SS PA 12 N/A YE -30 to +85 IP 67 CPB PA 12 N/A YE -25 to +85 IP 68, 69K SS PVDF N/A YE -25 to +70 IP 67 SS PA 12 N/A 200 N/A -30 to +85 IP 68 CPB PA 12 1000 1000 2500 2500 1000 1000 500 500 500 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 -25 to +70 IP 67 SS -25 to +70 IP 67 CPB -30 to +85 IP 68 -30 to +85 IP 67 -25 to +85 IP 68, 69K -25 to +85 IP 68, 69K -25 to +70 IP 67 -25 to +70 -25 to +70 Wi ri Dia ng gra m# Ma ti Co n g rds et Ou tpu t LE D er L ED Pow Fac e Ho usi ng tion tec Pro Op e Temrating p. ( °C) Voltage Sw itc Fre hing q. ( Hz ) Op era C u tin rre g nt ( mA ) TURCK mold-on connectors available on all cable sensors. See page A5. RK 4.2T-* RK 4.2T-* 1 2 YE RKV 4T-* RK 4T-* RKV 4T-* RKV 4T-* RK 4T-* RK 4T-* N/A YE RKC 254-*M 7 PA 12 N/A YE N/A YE SS PA 12 N/A YE CPB PA 12 N/A YE SS PVDF N/A YE CPB PA 12 N/A YE SS PA 12 N/A YE IP 67 SS SF N/A YE IP 67 SS WG N/A YE RKV 4T-* RK 4T-* RKV 4T-* RK 4T-* RK 4T-* RK 4T-* RK 4T-* RKV 4T-* RKV 4T-* 3 PA 12 1 Wiring Diagrams Diagram 1 2 2 Diagram 2 2 2 2 Diagram 3 10-30 VDC Barrels 18-33 VDC 3 3 Diagram 4 3 3 3 3 3 3 Diagram 5 10-65 VDC 10-65 VDC 1000 1000 500 ≤200 ≤200 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 SS PA 12 N/A YE 1000 500 ≤200 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 SS PA 12 N/A 1000 Remote -25 to +70 IP 67 CPB PA 12 180 ≤200 -25 to +80 IP 68, 69K SS SS RKV 4.4T-* RK 4.4T-* RK 4.4T-* 4 RK 4.4T-* RK 4.4T-* 5 YE N/A YE RK 4.21T-* 6 N/A YE RKV 4T-* 3 4 4 5 Diagram 6 5-30 VDC Diagram 7 10-30 VDC * Length in meters. For material descriptions see page M22. TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-7769 Fax: (763) 553-0708 www.turck.com D92
BI5U-M18-AP6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI5U-M18-AP6X-H1141”相匹配的价格&库存,您可以联系我们找货
BI5U-M18-AP6X-H1141
    • 1+1513.26210
    库存:15
