FEN20-4DIP-4DXP-DIN
FEN20-4DIP-4DXP-DIN
    TURCK(上海乐利)
    TURCK - FEN20-4DIP-4DXP-DIN - CONTROLLER, 0.10A
FEN20-4DIP-4DXP-DIN 数据手册
Compact IP20 Multiprotocol Ethernet I/O Station 4 Digital PNP Inputs and 4 Configurable Digital PNP Channels FEN20-4DIP-4DXP-DIN ■ EtherNet/IP™ Slave ■ Modbus TCP Slave ■ PROFINET Slave ■ Integrated Ethernet Switch ■ 10 Mbps / 100 Mbps supported ■ 2 x RJ45 Sockets for Fieldbus Connection ■ Can be mounted on DIN rail ■ 4 digital PNP inputs ■ 4 configurable PNP channels, DI or DO ■ 24 VDC ■ 1 A outputs ■ Degree of protection IP20 Type designation Ident-No. Ident-No (TUSA) FEN20-4DIP-4DXP-DIN 6931092 F6931092 Number of channels Operating / load voltage Operating current Electrical isolation Supply voltage Power dissipation, typical Voltage supply connection 8 12...30 VDC 100 mA 500V Galvanic Zone-Zone and Zone-Ethernet 24 VDC ð 2.4 W screw terminals Inputs Number of channels Input voltage Supply current Switching threshold Low level signal voltage High level signal voltage Low level signal current High level signal current Input delay Max. input current 8 24 VDC 700 mA 7V / 1.65mA < 7 VDC 7...30 VDC < 1.5 mA > 2 mA 2.5 ms 6 mA Outputs Number of channels Output voltage Output current per channel Output total current Load type Short-circuit protection 4 12...30 VDC, short-circuit proof 1A 4A Resistive, Inductive, Lamp Load yes Edition • Rev. A • 2017-06-20T20:48:33+02:00 System data Transmission rate Addressing modes Ethernet: Connection technology Ethernet Protocol detection Web server Service Interface Device Reset 10/100 Mbps; Full/Half Duplex; Auto Negotiation; Auto Crossing via Software 2 x RJ45 Sockets automatic 192.168.1.254 (Default) Ethernet via Push-button Modbus TCP Addressing Supported function codes Number of TCP connections Input Data Size Input register start address Output Data Size Output register start address Static IP, BOOTP, DHCP FC1, FC2, FC3, FC4, FC5, FC6, FC15, FC16, FC23 6 max. 1 register 0 (0x0000 hex) max. 1 register 2048 (0x0800 hex) 1/5 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Compact IP20 Multiprotocol Ethernet I/O Station 4 Digital PNP Inputs and 4 Configurable Digital PNP Channels FEN20-4DIP-4DXP-DIN acc. to EtherNet/IP™ specification < 150 ms supported 6 PROFINET Addressing Conformance class MinCycleTime Fast Start-Up (FSU) Diagnostics Topology detection Automatic addressing DCP B (RT) 1 ms < 150 ms acc. to PROFINET alarm handling supported supported Dimensions (W x L x H) Housing material Operating temperature Storage temperature Protection class Approvals 55 x 62.5 x 30mm Fiber-glass reinforced Polyamide (PA6-GF30) -40...70 ºC -40...85 ºC IP20 CE, cULus, Class I Div. 2 Edition • Rev. A • 2017-06-20T20:48:33+02:00 EtherNet/IP™ Addressing Quick Connect (QC) Device Level Ring (DLR) Number of CIP connections 2/5 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Compact IP20 Multiprotocol Ethernet I/O Station 4 Digital PNP Inputs and 4 Configurable Digital PNP Channels FEN20-4DIP-4DXP-DIN Ethernet RJ45 Ethernet Fieldbus cable (example): RJ45S RJ45S 441-2M (Ident no. U-06842) Power Supply Terminal Connection Edition • Rev. A • 2017-06-20T20:48:33+02:00 I/O Channels Power Supply 3/5 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Compact IP20 Multiprotocol Ethernet I/O Station 4 Digital PNP Inputs and 4 Configurable Digital PNP Channels FEN20-4DIP-4DXP-DIN Module LED Status LED Color Status Description ETH1 / ETH2 Green ON Ethernet Link (100 Mbps) Flashing Ethernet communication (100 Mbps) ON Ethernet Link (10 Mbps) Flashing Ethernet communication (10 Mbps) OFF No Ethernet link ON Active connection to a master flashing operational flashing 3 × (1Hz) ARGEE program running ON IP address conflict or status word active Flashing Blink/Wink command active OFF No power supply Green ON Diagnostics disabled Red ON Short-circuit yellow BUS Green red Edition • Rev. A • 2017-06-20T20:48:33+02:00 ERR 4/5 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Compact IP20 Multiprotocol Ethernet I/O Station 4 Digital PNP Inputs and 4 Configurable Digital PNP Channels FEN20-4DIP-4DXP-DIN Process Data Mapping Modbus TCP Register Mapping Reg Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Inputs (RO) 0x0000 - - - - - Status (RO) 0x0001 - FCE - - CFG Diag (RO) 0x0002 - - - - - Bit 9 Bit 8 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 - - DI7 DI6 DI5 DI4 DI3 DI2 DI1 DI0 - - - - - - - - Diag - - - - - - - - - COM V1 low Bit 0 Warn - - I/O Diag Outputs (RW) 0x0800 - - - - I/O Diag (RO) 0xA000 - - - - - - - - - - - - DO3 DO2 DO1 DO0 - - - - - - - IGS Bit 8 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 - - - - - - - - SCO3 SCO2 SCO1 SCO0 EtherNet/IP™ Data Mapping INPUT Word Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 0 - FCE - - CFG Bit 9 COM V1 low Diag Warn 1 - - - - - - - - DI7 DI6 DI5 DI4 DI3 DI2 DI1 2 - - Sched - - - - - - - - - - - - DI0 I/O Diag 3 OUTPUT Word - - Diag - - SCO3 SCO2 SCO1 SCO0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 - - - - - - - IGS Bit 9 Bit 8 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 - - - - - - - - - - - - - - - - 1 - - - - - - - - - - - - DO3 DO2 DO1 DO0 PROFINET Process Data Byte Inputs Outputs Bit 7 Bit 6 Bit 5 Bit 4 Bit3 Bit 2 Bit 1 Bit 0 0 DI7 DI6 DI5 DI4 DI3 DI2 DI1 DI0 1 - - - - - - - - 0 - - - - DO3 DO2 DO1 DO0 1 - - - - - - - - Key: Digital input x COM Communication error on internal module bus DOx Digital output x CFG I/O configuration error IGS Input group short-circuit FCE I/O-ASSISTANT Force Mode active SCOx Short-circuit output x I/O Diag I/O diagnostic detected Diag Warn Diagnostic at least on 1 channel Sched Diag Manufacturer-specific diagnostics configured and active V1 low Undervoltage V1 - - Edition • Rev. A • 2017-06-20T20:48:33+02:00 DIx 5/5 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com
FEN20-4DIP-4DXP-DIN 价格&库存
很抱歉,暂时无法提供与“FEN20-4DIP-4DXP-DIN”相匹配的价格&库存,您可以联系我们找货
