BI1-EG05-Y1
BI1-EG05-Y1
    TURCK(上海乐利)
    TURCK - BI1-EG05-Y1 - INDUCTIVE SENSOR, 1MM, M5 X 0.5
BI1-EG05-Y1 数据手册
Inductive sensor BI1-EG05-Y1 ■ ATEX category II 1 G, Ex zone 0 ■ ATEX category II 1 D, Ex zone 20 ■ SIL2 as per IEC 61508 ■ Threaded barrel, M5 x 0.5 ■ Stainless steel, 1.4427 SO ■ DC 2-wire, nom. 8.2 VDC ■ Output acc. to DIN EN 60947-5-6 (NAMUR) ■ Cable connection Wiring Diagram Type designation Ident no. BI1-EG05-Y1 1003240 Rated switching distance Sn Mounting conditions Secured operating distance Correction factors Repeat accuracy Temperature drift Hysteresis Ambient temperature 1 mm Flush ð (0,81 x Sn) mm St37 = 1; Al = 0.3; stainless steel = 0.7; Ms = 0.4 ð 2 % of full scale ð ± 10 % 1…10 % -25…+70 °C Output function Switching frequency Voltage Non-actuated current consumption Actuated current consumption 2-wire, NAMUR 5 kHz Nom. 8.2 VDC ï 2.1 mA ð 1.2 mA Approval acc. to KEMA 02 ATEX 1090X Design Dimensions Housing material Active area material Max. tightening torque housing nut Electrical connection Cable quality Cable cross section Threaded barrel, M5 × 0.5 30 mm Stainless steel, 1.4427 SO Plastic, PBT-GF20 5 Nm Cable 3 mm, Blue, Lif9YYW, PVC, 2m Inductive sensors detect metal objects contactless and wear-free. For this, they use a high-frequency electromagnetic AC field that interacts with the target. Inductive sensors generate this field via an RLC circuit with a ferrite coil. 2 x 0.14 mm 55 Hz (1 mm) 30 g (11 ms) IP67 6198 years acc. to SN 29500 (Ed. 99) 40 °C 2 Edition • 2017-09-20T10:49:07+02:00 Vibration resistance Shock resistance Protection class MTTF Functional principle 1/4 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI1-EG05-Y1 2xB Distance W 3 x Sn Distance T 3xB Distance S 1.5 x B Distance G 6 x Sn Diameter active area B Ø 5 mm Edition • 2017-09-20T10:49:07+02:00 Distance D 2/4 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI1-EG05-Y1 Accessories Type code Ident no. Description IMX12-DI01-2S-2T-0/ 7580020 Isolating switching amplifier, 2-channel; SIL2 acc. to IEC 24VDC 61508; Ex-proof version; 2 transistor outputs; input Namur signal; ON/OFF switchable monitoring of wire-break and short-circuit; toggle between NO/NC mode; signal doubling; removable screw terminals; 12.5 mm wide; 24 VDC power supply Wiring accessories Type code Ident no. Description IM1-22EX-T 7541232 Isolating switching amplifier, 2-channel; 2 transistor outputs; input NAMUR signal; selectable ON/OFF mode for wirebreak and short-circuit monitoring; switchable between NO / NC mode; removable terminal blocks; width 18 mm; universal Edition • 2017-09-20T10:49:07+02:00 voltage supply unit 3/4 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Inductive sensor BI1-EG05-Y1 Operating manual Intended use This device fulfills the directive 2014/34/EC and is suited for use in explosion hazardous areas according to EN 60079-0:2012 + A11 and EN 60079-11:2012. Further it is suited for use in safety-related systems, including SIL2 as per IEC 61508. In order to ensure correct operation to the intended purpose it is required to observe the national regulations and directives. For use in explosion hazardous areas conform to classification II 1 G and II 1 D (Group II, Category 1 G, electrical equipment for gaseous atmospheres and category 1 D, electrical equipment for dust atmospheres). Marking (see device or technical data sheet) É II 1 G and Ex ia IIC T6 Ga and É II 1 D Ex ia IIIC T95 °C Da acc. to EN 60079-0, -11 Local admissible ambient temperature -25…+70 °C Installation / Commissioning These devices may only be installed, connected and operated by trained and qualified staff. Qualified staff must have knowledge of protection classes, directives and regulations concerning electrical equipment designed for use in explosion hazardous areas. Please verify that the classification and the marking on the device comply with the actual application conditions. This device is only suited for connection to approved Exi circuits according to EN 60079-0 and EN 60079-11. Please observe the maximum admissible electrical values. After connection to other circuits the sensor may no longer be used in Exi installations. When interconnected to (associated) electrical equipment, it is required to perform the "Proof of intrinsic safety" (EN60079-14). Attention! When used in safety systems, all content of the security manual must be observed. Installation and mounting instructions Avoid static charging of cables and plastic devices. Please only clean the device with a damp cloth. Do not install the device in a dust flow and avoid build-up of dust deposits on the device. If the devices and the cable could be subject to mechanical damage, they must be protected accordingly. They must also be shielded against strong electro-magnetic fields. The pin configuration and the electrical specifications can be taken from the device marking or the technical data sheet. service / maintenance Edition • 2017-09-20T10:49:07+02:00 Repairs are not possible. The approval expires if the device is repaired or modified by a person other than the manufacturer. The most important data from the approval are listed. 4/4 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com
BI1-EG05-Y1 价格&库存
很抱歉,暂时无法提供与“BI1-EG05-Y1”相匹配的价格&库存,您可以联系我们找货
BI1-EG05-Y1
    • 1+692.68679
    库存:2
