BI4-G12-ADZ32X-B3131
    TURCK(上海乐利)
    TURCK - BI4-G12-ADZ32X-B3131 - INDUCTIVE PROXIMITY SENSOR
BI4-G12-ADZ32X-B3131 数据手册
Housing Style 12 mm - Embeddable, microfast ® Connection Part Number ID Number Sen s Ran ing ge (mm ) Inductive Sensors Features Bi 2-G12-ADZ32X-B3131 T4205001 Bi 2U-G12-ADZ32X-B3131 M4281005 Uprox 2 Bi 4-G12-ADZ32X-B3131 T4205031 Ext. Range 4 Bi 2-G12-AZ33X-B3131 T1304032 Output 2 2-Wire AC/DC Short-circuit Protected 2 2-Wire AC/DC 12 mm - Embeddable, microfast Connection, PTFE Coated Bi 2-GT12H-ADZ32X-B3131/S34 T4205093 WFI 2 Bi 2-GT12H-ADZ32X-B3131/S34/S1589 T4205096 WFI/weldguard ® 2 Bi 2-GT12-ADZ32X-B3131/S34 T4205005 WFI 2 Bi 2U-GT12-ADZ32X-B3131 M4281015 Uprox 2 Bi 4-GT12H-ADZ32X-B3131 T4205097 Stoneface 4 Bi 4-GT12H-ADZ32X-B3131/S1589 T4205087 weldguard 4 Bi 2-GT12-AZ33X-B3131/S34 T1304082 2-Wire AC/DC Short-circuit Protected 2 2-Wire AC/DC 12 mm - Nonembeddable, microfast Connection Ni 4-G12-ADZ32X-B3131 T4205201 Ni 8U-G12-ADZ32X-B3131 M4281105 Ni 4-G12-AZ33X-B3131 T1304232 4 Ext. Range, Uprox 8 2-Wire AC/DC Short-circuit Protected 4 2-Wire AC/DC 12 mm - Nonembeddable, microfast Connection, PTFE Coated Ni 4-GT12-ADZ32X-B3131/S34 T4205205 WFI 4 Ni 4-GT12-AZ33X-B3131/S34 T1304292 WFI 4 Ni 4-GT12H-ADZ32X-B3131/S34/S1589 T4205293 weldguard 4 T4205480-1 weldguard 8 M4281115 Uprox 8 Ni 8-GT12H-ADZ32X-B3131/S1589 Ni 8U-GT12-ADZ32X-B3131 2-Wire AC/DC For detailed sensor specifications see Section M. Normally Closed versions available upon request, consult factory. C65 B1008 www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 Industrial Automation 20-250 VAC 10-300 VDC # Wir in Dia g gra m Ma ti Cor n g dse t Pow er L ED Ou tpu t LE D Fac e usi ng tec tio n Ho Voltage Pro Sw it Fre ching q. ( Hz) Op e Cur ratin ren g t (m A) Op er Tem ating p. ( °C) TURCK mold-on connectors available on all cable sensors. See page M25. 20 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE KB 3T-* 1 20 ≤100 -30 to +85 IP 67 CPB PA 12 N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE KB 3T-* 1 Wiring Diagrams Diagram 1 20-250 VAC 10-300 VDC 20 ≤100 -25 to +70 IP 67 TC TC N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 TC WG N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 TC TC N/A YE KB 3T-* 1 20 ≤100 -30 to +85 IP 67 TC TC N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 TC TC N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 TC TC N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 TC TC N/A YE KB 3T-* 1 Barrels 20-250 VAC 10-300 VDC 20-250 VAC 10-300 VDC 20-250 VAC 10-300 VDC 20 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE KB 3T-* 1 20 ≤100 -30 to +85 IP 67 CPB PA 12 N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE KB 3T-* 1 20-250 VAC 10-300 VDC 20 ≤100 -25 to +70 IP 67 TC PA 12 N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 TC PA 12 N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 TC WG N/A YE KB 3T-* 1 20 ≤100 -25 to +70 IP 67 TC WG N/A YE KB 3T-* 1 20 ≤100 -30 to +85 IP 67 TC PA 12 N/A YE KB 3T-* 1 20-250 VAC 10-300 VDC * Length in meters. For material descriptions see page M36. www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · TURCK Inc. Minneapolis, MN 55441 B1008 C66
BI4-G12-ADZ32X-B3131 价格&库存
很抱歉,暂时无法提供与“BI4-G12-ADZ32X-B3131”相匹配的价格&库存,您可以联系我们找货
  • 1+2939.70124
库存:4
