BI4U-M12-RP6X-H1141
BI4U-M12-RP6X-H1141
    TURCK(上海乐利)
    TURCK - BI4U-M12-RP6X-H1141 - INDUCTIVE SENSOR, 4MM, M12 X 1
BI4U-M12-RP6X-H1141 数据手册
Inductive sensor BI4U-M12-RP6X-H1141 ■ M12 × 1 threaded barrel ■ Chrome-plated brass ■ Factor 1 for all metals ■ Protection class IP68 ■ Resistant to magnetic fields ■ Large switching distance ■ Recessed mountable ■ DC 3-wire, 10…30 VDC ■ NC contact, PNP output ■ M12 x 1 male connector Wiring Diagram BI4U-M12-RP6X-H1141 1634846 M1634846 Rated switching distance Sn Mounting conditions Secured operating distance Repeat accuracy Temperature drift Hysteresis Ambient temperature 4 mm Flush ð (0,81 x Sn) mm ð 2 % of full scale ð ± 10 % ð ± 15 %, ð -25 °C v ï +70 °C 3…15 % -30…+85 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Isolation test voltage Short-circuit protection Voltage drop at Ie Wire breakage/Reverse polarity protection Output function Protection class Switching frequency 10…30 VDC ð 10 % Uss ð 200 mA ð 20 mA ð 0.1 mA ð 0.5 kV yes/ Cyclic ð 1.8 V yes/ Complete 3-wire, NC contact, PNP ÷ 2 kHz Design Dimensions Housing material Active area material Max. tightening torque housing nut Electrical connection Vibration resistance Shock resistance Protection class MTTF Threaded barrel, M12 × 1 52 mm Metal, CuZn, Chrome-plated Plastic, LCP 10 Nm Connector, M12 × 1 55 Hz (1 mm) 30 g (11 ms) IP68 874 years acc. to SN 29500 (Ed. 99) 40 °C Switching state LED yellow Functional principle Inductive sensors detect metal objects contactless and wear-free. Due to the patented multi-coil system, uprox®+ sensors have distinct advantages over conventional sensors. They excel in largest switching distances, maximum flexibility and operational reliability as well as efficient standardization. Edition • 2017-09-15T05:22:49+02:00 Type designation Ident-No. Ident-No (TUSA) 1/4 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Inductive sensor BI4U-M12-RP6X-H1141 Distance D 24 mm Distance W 3 x Sn Distance T 3xB Distance S 1.5 x B Distance G 6 x Sn Diameter active area B Ø 12 mm All flush mountable uprox®+ threaded barrel types are also recessed mountable. Safe operation is ensured if Edition • 2017-09-15T05:22:49+02:00 the sensor is screwed in by half a turn. 2/4 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Inductive sensor BI4U-M12-RP6X-H1141 Accessories Type code Ident-No. Description PN-M12 6905309 Impact protection nut for M12x1 threaded barrel devices; material: Stainless steel A2 1.4305 (AISI 303) QM-12 6945101 Quick-mount bracket with dead-stop; material: Chrome-plated brass Male thread M16 x 1. Note: The switching distance of proximity switches can be reduced by the use of quickmount brackets. BST-12B 6947212 Fixing clamp for threaded barrel devices, with dead-stop; material: PA6 MW-12 6945003 Mounting bracket for threaded barrel devices; material: Stainless steel A2 1.4301 (AISI 304) BSS-12 6901321 Mounting bracket for smooth and threaded barrel devices; Edition • 2017-09-15T05:22:49+02:00 material: Polypropylene 3/4 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Inductive sensor BI4U-M12-RP6X-H1141 Wiring accessories Type code Ident-No. Description RKC4.4T-2/TEL 6625013 Connection cable, female M12, straight, 4-pin, cable length: 2 m, sheath material: PVC, black; cULus approval; other cable Edition • 2017-09-15T05:22:49+02:00 lengths and qualities available, see www.turck.com 4/4 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com
BI4U-M12-RP6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI4U-M12-RP6X-H1141”相匹配的价格&库存,您可以联系我们找货
