BI8-M18-AP6X-H1141
BI8-M18-AP6X-H1141
    TURCK(上海乐利)
    TURCK - BI8-M18-AP6X-H1141 - INDUCTIVE PROXIMITY SENSOR
BI8-M18-AP6X-H1141 数据手册
Housing Style 18 mm - Embeddable eurofast ® Connection Part Number ID Number Bi 5-M18-AD4X-H1141 Bi 7-M18-AD4X-H1141 T4414500 T4414541 Bi Bi Bi Bi Bi Bi 5-EM18-AN6X-H1141 5-M18-AN6X-H1141 5U-EM18-AN6X-H1141 5U-M18-AN6X-H1141 7-EM18WD-AN6X-H1141 8-M18-AN6X-H1141 T4614601 T4614600 M1635350 M1635150 M4614534 T4615100 Bi Bi Bi Bi Bi Bi Bi Bi 5-EM18-AP6X-H1141 5-M18-AP6X-H1141 5U-EM18-AP6X-H1141 5U-M18-AP6X-H1141 7-EM18WD-AP6X-H1141 8-M18-AP6X-H1141 8-EM18H-AP6X-H1141 8-EM18H-AP6X-H1141/S1589 T4614501 T4614500 M1635340 M1635140 M4614531 T4615000 T4615094 T4615099 Features Extended Range Uprox Uprox Washdown Extended Range Uprox Uprox Washdown Ext. Range Ext. Range Weldguard Bi 5-EM18-VN4X-H1141 Bi 5-M18-VN4X-H1141 Bi 8-M18-VN4X-H1141 T4614699 T1571800 T4590702 Comp. Output Bi 5-M18-VP4X-H1141 Bi 8-M18-VP4X-H1141 T1561800 T4590701 Comp. Output Bi 5-M18-Y1X-H1141 M4015200 Comp. Output Ext. Range Ext. Range Sen s Ran i n g ge (m m) Inductive Sensors 5 7 5 5 5 5 7 8 5 5 5 5 7 8 8 8 5 5 8 Output 2-Wire DC 3-Wire DC NPN 3-Wire DC PNP 4-Wire DC NPN 5 8 4-Wire DC PNP 5 2-Wire NAMUR For detailed sensor specifications see Section A. Normally Closed versions available upon request, consult factory. C87 TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-PROX Fax: (763) 553-0708 www.turck.com Industrial Automation TURCK mold-on connectors available on all cable sensors. See page A5. 10-30 VDC 10-30 VDC 10-65 VDC ≤100 ≤100 -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE 1000 1000 2500 2500 1000 500 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -30 to +85 IP 68 SS PA 12 N/A YE -30 to +85 IP 67 CPB PA 12 N/A YE -25 to +85 IP 68, 69K SS PVDF N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE 1000 1000 2500 2500 1000 500 500 500 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -30 to +85 IP 68 SS PA 12 N/A YE -30 to +85 IP 67 CPB PA 12 N/A YE -25 to +85 IP 68, 69K SS PVDF N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 SS SF N/A YE -25 to +70 IP 67 SS WG N/A YE 1000 1000 1000 ≤200 ≤200 ≤200 -25 to +70 IP 67 SS PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE -25 to +70 IP 67 CPB PA 12 N/A YE Wi ri Dia ng gra m# Ma ti Co n g rds et Ou tpu t LE D er L ED Pow Fac e Ho usi ng tion tec Pro 1000 1000 RK 4.2T-* RK 4.2T-* 1 RKV 4T-* RK 4T-* RKV 4T-* RKV 4T-* RK 4.4Z-*/S90 RK 4T-* 2 RKV 4T-* RK 4T-* RKV 4T-* RK 4T-* RK 4.4Z-*/S90 RK 4T-* RKV 4T-* RKV 4T-* 3 RKV 4.4T-* RK 4.4T-* RK 4.4T-* 4 1 Wiring Diagrams Diagram 1 2 2 2 Diagram 2 2 2 3 Barrels 10-65 VDC Op e Temrating p. ( °C) Voltage Sw itc Fre hing q. ( Hz ) Op e C u ratin rre g nt ( mA ) Industrial Automation Diagram 3 3 3 3 3 3 3 Diagram 4 4 4 Diagram 5 1000 1000 ≤200 ≤200 -25 to +70 IP 67 CPB PA 12 N/A YE IP 67 CPB PA 12 N/A YE RK 4.4T-* RK 4.4T-* 5 -25 to +70 1000 Remote -25 to +70 IP 67 CPB PA 12 N/A YE RK 4.21T-* 6 5 10-65 VDC Diagram 6 5-30 VDC * Length in meters. For material descriptions see page A34. TURCK Inc. 3000 Campus Drive Minneapolis, MN 55441 Application Support: 1-800-544-PROX Fax: (763) 553-0708 www.turck.com C88
BI8-M18-AP6X-H1141 价格&库存
很抱歉,暂时无法提供与“BI8-M18-AP6X-H1141”相匹配的价格&库存,您可以联系我们找货
