BS 8251-0/PG9
BS 8251-0/PG9
    TURCK(上海乐利)
    TURCK - BS 8251-0/PG9 - SENSOR CONNECTOR, M12, PLUG, 5POS, CABLE
BS 8251-0/PG9 数据手册
Industrial Automation 4, 5 and 8-Wire M12 eurofast ® Field Wireable Connectors, Standard and Reverse Key • Right Angle Male Connectors • IEC IP 67 Protection www.turck.us Part Number 1-800-544-7769 Housing Specs. Application BS 8241-0 PBT, Black PG 7 cable gland accepts 4-6 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 60 V, 4 A Mates with standard key 4-pin cordsets and receptacles BS 8241-0/PG 9 PBT, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals 85°C 60 V, 4 A Mates with standard key 4-pin cordsets and receptacles BS 8251-0/PG 9 PBT, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 125 V, 4 A Mates with standard key 5-pin cordsets and receptacles BSWS 8241-0 PBT, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 250 V, 4 A Mates with reverse key 4-pin cordsets and receptacles BSWS 8251-0 PBT, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 125 V, 4 A Mates with reverse key 5-pin cordsets and receptacles BS 8281-0 Nylon, Black PG 9 cable gland accepts 6-8 mm cable diameter Screw terminals accepts up to 18 AWG conductors 85°C 30 VAC/ 75 VDC, 2 A Mates with standard key 8-pin cordsets and receptacles Fax: (763) 553-0708 TURCK Inc. Minneapolis, MN 55441 Pinout Field Wireables Drawing B2006 D166
BS 8251-0/PG9 价格&库存
很抱歉,暂时无法提供与“BS 8251-0/PG9”相匹配的价格&库存,您可以联系我们找货
