B1N360V-Q20L60-2LU3-H1151
    TURCK(上海乐利)
    TURCK - B1N360V-Q20L60-2LU3-H1151 - INCLINOMETER, 360DEG, 30VDC
B1N360V-Q20L60-2LU3-H1151 数据手册
Inclinometer B1N360V-Q20L60-2LU3-H1151 ■ Rectangular, plastic, PC ■ Compact housing ■ Connection via M12 × 1 male ■ Response time 0.1 s ■ 10…30 VDC ■ Two counter-running 0.1 … 4.9 V analog outputs improve machine safety through redundancy Wiring Diagram Type designation Ident-No. Ident-No (TUSA) B1N360V-Q20L60-2LU3-H1151 1534069 M1534069 Measuring range Mounting conditions Repeatability Linearity deviation Temperature drift Resolution Ambient temperature 0…360° Vertical ð 0.2 % of measuring range |A - B| ð 0.6 % ð ± 0.05 % / K ð 0.14 ° -30…+70 °C Operating voltage Isolation test voltage Short-circuit protection Wire breakage/Reverse polarity protection Output function Voltage output Current consumption 10…30 VDC ð 0.5 kV yes yes/ Complete 5-pin, Analog output 0.1…4.9V 2 outputs, one for CW and one for CCW ï 40 kò 0.1 s Time for the output signal to reach 90% of the adjusted measuring range 50…105 mA (voltage-dependent) Design Dimensions Housing material Electrical connection Vibration resistance Shock resistance Protection class MTTF Rectangular, Q20L60 60 x 30 x 20 mm Plastic, PC Connector, M12 × 1 55 Hz (1 mm) 30 g (11 ms) IP68/IP69K 203 years acc. to SN 29500 (Ed. 99) 40 °C The TURCK inclinometers incorporate a micromechanical pendulum, operating on the principle of MEMS technology (Mikro Elektro Mechanic Systems). The pendulum basically consists of two 'plate' electrodes arranged in parallel with a dielectric placed in the middle. When the sensor is inclined, the dielectric in the middle moves, causing the capacitance ratio between both electrodes to change. The downstream electronics evaluates this change in capacitance and generates a corresponding output signal. Edition • 2017-09-15T03:56:50+02:00 Load resistance voltage output Response time Functional principle 1/3 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Inclinometer B1N360V-Q20L60-2LU3-H1151 Mounting instructions/Description Tilt angle Adjusting the measuring range via TX1-Q20L60 teach adapter Setting the angular range in CW direction: ■ Move sensor to start position ■ Press and hold Teach-Gnd until the output is set to 0.1 V (approx. 1 s) ■ Move sensor to end position ■ Press and hold Teach-Gnd until the output is set to 4.9 V (approx. 3 s) Resetting the angular range: ■ Press and hold Teach-Gnd until the output is set to 2.5 V (approx. 6 s) ■ Angle measurement is set back to 360° degrees (in mounting position "connector outgoing topwards" the sensor provides an output signal in accordance Edition • 2017-09-15T03:56:50+02:00 with 0° degrees) 2/3 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com Inclinometer B1N360V-Q20L60-2LU3-H1151 Accessories Type code Ident-No. Description IM43-13-SR 7540041 Trip amplifier; 1-channel; input 0/4…20 mA or 0/2…10 V; supply of 2- or 3-wire transmitters/sensors; limit value adjustment via teach button; three relay outputs with one NO contact each; removable terminal blocks; 27 mm wide; universal voltage supply 20…250 VUC; further Limit value indicators are described in our "Interface Technology" catalog. SG-Q20L60 6901100 Protective frame for Q20L60; protects against mechanical impact; stainless steel TX1-Q20L60 6967114 Teach adapter for inductive encoders, linear position, angle, Edition • 2017-09-15T03:56:50+02:00 ultrasonic and capacitive sensors 3/3 TURCK Inc. ñ 3000 Campus Drive Minneapolis, MN 55441-2656 ñ Phone: 763-553-7300 ñ Application Support: 1-800-544-7769 ñ Fax 763-553-0708 ñ www.turck.com
B1N360V-Q20L60-2LU3-H1151 价格&库存
很抱歉,暂时无法提供与“B1N360V-Q20L60-2LU3-H1151”相匹配的价格&库存,您可以联系我们找货
