BC10-M30-VP4X
BC10-M30-VP4X
    TURCK(上海乐利)
    TURCK - BC10-M30-VP4X - Capacitive Proximity Sensor, M30, 10 mm, PNP, 10 Vdc to 65 Vdc, Pre-wired
BC10-M30-VP4X 数据手册
Capacitive sensor BC10-M30K-VP4X ■ M30 × 1.5 threaded barrel ■ Chrome-plated brass ■ Fine adjustment via potentiometer ■ DC 4-wire, 10…65 VDC ■ Complementary contact, PNP output ■ Cable connection Wiring Diagram Type designation Ident no. BC10-M30K-VP4X 2503022 Rated switching distance (flush) Rated switching distance (non-flush) Secured operating distance Hysteresis Temperature drift Repeat accuracy Ambient temperature 10 mm 10 mm ð (0.72 x Sn) mm 2…20 % type 20 % ð 2 % of full scale -25…+70 °C Operating voltage Residual ripple DC rated operational current No-load current I0 Residual current Switching frequency Isolation test voltage Output function Short-circuit protection Voltage drop at Ie Wire breakage/Reverse polarity protection 10…65 VDC ð 10 % Uss ð 200 mA ð 15 mA ð 0.1 mA 0.1 kHz ð 0.5 kV 4-wire, Complementary contact, PNP yes/ Cyclic ð 1.8 V yes/ Complete Approvals UL Design Dimensions Housing material Active area material Admissible pressure on front cap Max. tightening torque housing nut Electrical connection Cable quality Cable cross section Threaded barrel, M30 × 1.5 62.5 mm Metal, CuZn, Chrome-plated Plastic, PA12-GF30, yellow ð 3 bar 25 Nm Cable Ø 5.2, LifYY, PVC, 2m Vibration resistance Shock resistance Protection class MTTF 4 x 0.34 mm 55 Hz (1 mm) 30 g (11 ms) IP67 1080 years acc. to SN 29500 (Ed. 99) 40 °C Switching state LED yellow Functional principle Capacitive proximity switches are designed for non-contact and wear-free detection of electrically conductive as well as non-conductive metal objects. Edition • 2017-09-20T13:10:28+02:00 2 1/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Capacitive sensor BC10-M30K-VP4X Mounting instructions/Description minimum distances Distance D 60 mm Distance W 30 mm Distance S 45 mm Distance G 60 mm Diameter active area B Ø 30 mm The given minimum distances have been checked against the standard switching distance. Should the sensitivity of the sensors be changed via potentiometer, the data sheet specifications no longer Edition • 2017-09-20T13:10:28+02:00 apply. 2/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com Capacitive sensor BC10-M30K-VP4X Accessories Type code Ident no. Description MAP-M30 6950013 Mounting adapter; material: Polypropylene; sensor replacement with filled container possible (adapter remains in container during sensor replacement) BST-30B 6947216 Fixing clamp for threaded barrel devices, with dead-stop; ma- Edition • 2017-09-20T13:10:28+02:00 terial: PA6 3/3 Hans Turck GmbH & Co.KG ñ D-45472 Mülheim an der Ruhr ñ Witzlebenstraße 7 ñ Tel. 0208 4952-0 ñ Fax 0208 4952-264 ñ more@turck.com ñ www.turck.com
BC10-M30-VP4X
物料型号:BC10-M30K-VP4X
器件简介: - 电容式接近传感器,用于非接触式、无磨损检测导电和非导电金属物体。 - 螺纹尺寸:M30×1.5 - 细调通过电位器实现 - 直流4线制,PNP输出 - 电缆连接
引脚分配: - 接线图显示了BN、BU、WH、BK的引脚连接方式
参数特性: - 额定切换距离(齐平):10mm - 额定切换距离(非齐平):10mm - 安全工作距离:s(0.72xSn) mm - 滞后:2...20% - 温度漂移:type20% - 重复精度:s2%的全刻度 - 环境温度:-25..+70°C - 工作电压残余纹波:s10%U. - 直流额定工作电流:s200mA - 空载电流:s15mA - 残余电流:s0.1mA - 切换频率:0.1kHz - 隔离测试电压:≤0.5kV - 输出功能:4线制,互补接触,PNP - 短路保护:是/周期性 - 电流下降:s1.8V - 断线/反极性保护:是/完全 - 认证:UL - 设计:螺纹筒,M30x1.5 - 尺寸:62.5mm - 外壳材料:金属,CuZn,镀铬 - 活动区域材料:塑料,PA12-GF30,黄色 - 前盖允许的压力:<3bar - 最大拧紧扭矩:25Nm - 电气连接:电缆 - 电缆质量:05.2,LifYY,PVC,2m - 电缆截面积:4x0.34mm - 抗振性:55Hz(1 mm) - 抗冲击性:30g(11ms) - 保护等级:IP67 - MTTF:1080年,根据SN29500(Ed.99)40C
功能详解: - 电容式接近传感器用于非接触式检测金属物体,具有非接触式和无磨损的特点。 - 传感器的灵敏度可以通过电位器进行微调。
应用信息: - 适用于工业自动化领域,用于检测金属物体。
封装信息: - 安装说明/描述中提供了最小距离D、W、S、G和活动区域直径B的尺寸信息。
BC10-M30-VP4X 价格&库存
很抱歉,暂时无法提供与“BC10-M30-VP4X”相匹配的价格&库存,您可以联系我们找货
