CMB 8181-0
CMB 8181-0
    TURCK(上海乐利)
    TURCK - CMB 8181-0 - SENSOR CONNECTOR, M12, RCPT, 8POS, CABLE
CMB 8181-0 数据手册
M12 eurofast ® Connectivity 4, 5 and 8-Pin Field Wireable Connectors, Shielded, Screw Terminals • Screw Terminals • No Soldering Required • IEC IP67 Protection Female Part Number Male Part Number Features Pinout Female CMB 81.. CMB 8141-0 CMB 8241-0 CMBS 8141-0 CMBS 8241-0 CMB 82.. Nickel Plated Brass, PG9 cable gland, accepts 6-8 mm cable diameter, screw terminal accepts up to 18 AWG conductors, 85°C, 250 V, 4 A, Metal, fully shielded Mates with standard key 4-pin cordsets and receptacles Male Female CMBS 81.. CMB 8151-0 CMB 8251-0 CMBS 8151-0 CMBS 8251-0 Nickel Plated Brass, PG9 cable gland, accepts 6-8 mm cable diameter, screw terminal, accepts up to 18 AWG conductors, 85°C, 60 V, 4 A, metal, fully shielded Mates with standard key 5-pin cordsets and receptacles Male Female CMBS 82.. CMB 8181-0 www.turck.us · 1-800-544-7769 · Fax: (763) 553-0708 · CMBS 8181-0 Nickel Plated Brass, PG9 cable gland accepts 6-8 mm cable diameter, screw terminal accepts up to 18 AWG conductors, 85°C, 60 V, 2 A, metal, fully shielded, mates with standard key 8-pin cordsets and receptacles TURCK Inc. Minneapolis, MN 55441 Male B2007 D89 Field Wireables Housing Style
CMB 8181-0 价格&库存
很抱歉,暂时无法提供与“CMB 8181-0”相匹配的价格&库存,您可以联系我们找货
