C5-A30X/120VAC
C5-A30X/120VAC
    TURCK(上海乐利)
    TURCK - C5-A30X/120VAC - POWER RELAY, 3PDT, 16A, 120VAC, SOCKET
C5-A30X/120VAC 数据手册
MRC 3-Pole, Square Base, Power Relay C5-A30 General purpose Three change-over contacts Relay compatible with sockets: S5-S, S5-L, S5-P, S5-PO 16 A 400 V AC1 16 A 30 V DC1 0.5 A 110 V DC1 0.2 A 220 V DC1 Contacts 1 4 2 5 3 6 A 12 14 22 24 32 34 A1(+) 11 21 31 A2 7 8 9 B Materials: Standard, code 0 Max. switching current Max. peak inrush current (20 ms) Max. switching voltage Max. AC load (Table 1) Max. DC load (Table 2) Electrical Life, ops. x 106 Table 1 10 Coils (Ohms ±10% @ 20°C) Pull-in voltage Drop-out voltage Nominal coil power Res Cos ϕ 0.4 Ω Ops. VAC 24 48 115 230 400 1 0.1 0.66 1.33 2 KVA 2.6 3.3 65 286 1K7 6K8 18K8 AgNi 16 A 40 A 400 V 4 KVA ≤0.8 x Un ≥0.1 x Un 2.4 VA (AC)/1.4 W (DC) mA VDC 100 50 21 10 6 24 48 110 220 Ω 414 1K6 8K1 35K6 mA 58 30 13 6.5 4 Insulation Table 2 Max. DC Load 16 10 Dielectric strength (1 minute): Open contacts Between adjacent poles Between contacts and coil Isolation resistance at 500 V Isolation, IEC 61810-5: 1,000 V 4 KV 4 KV ≥3G Ω 4 KV/3 Amps. DC1 L/R 40ms Specifications 1 0.1 50 100 150 200 Volts Operate time + bounce time 20 ms Release time + bounce time 10 ms Ambient temperature -40°C (no ice) to +70°C Mechanical life ops. 10 Mill. AC, 20 Mill. DC relays Electrical life at nominal load ≥100,000 ops. Operating frequency at nominal load 1,200/hour Protection degree IP 40/RT1 Weight avg. 95 g 56 35 Dimensions - mm 1 2 3 4 7 5 8 6 9 B A 35 11.05 11.05 4.75 FASTON .187 4.6 5.5 8.3 7.7 1.3 C.I. 32 B1201 Standard Types AC 50 Hz, (60 Hz): 24, 48, 115, (120), 230, (240) X = LED (standard) C5-A30X ........VAC RC suppressor C5-A30R........VAC DC 24, 48, 110, 220 X = LED, no polarity (standard) Free-wheeling diode Polarity and free-wheeling diodes AC/DC bridge rectifier (24, 48 or 60 V) C5-A30X ....... VDC C3-A30DX .... VDC C5-A30FX..... VDC C5-A30BX .... VDC ø1.5 8.9 IEC 6094 www.turck.us • 1-800-544-7769 • Fax: (763) 553-0708 • IEC 61810 TURCK Inc. Minneapolis, MN 55441
C5-A30X/120VAC 价格&库存
很抱歉,暂时无法提供与“C5-A30X/120VAC”相匹配的价格&库存,您可以联系我们找货
