BC807-40
BC807-40
    AGERTECH(艾吉芯)
    SOT-23
    PNP 电流:0.5A 电压:45V
BC807-40 数据手册
BC807/BC808-16/-25/-40 PNP Transistor Features  For switching, AF driver and amplifier applications  These transistors are subdivided into three groups SOT-23 -16, -25 and -40, according to their current gain. As complementary types the NPN transistors BC817 and BC818 are recommended Absolute Maximum Ratings (TA=25℃, unless otherwise noted) Parameter 1 Base 2. Emitter 3. Collector Symbol Collector Base Voltage BC807 BC808 BC807 BC808 Collector Emitter Voltage Value VCBO VCEO VEBO IC PC TJ,TSTG Emitter Base Voltage Collector Current Power Dissipation Operation Junction and Storage Temperature Range Unit -50 -30 -45 -25 -5 -0.5 0.3 -55 to 150 V V V A W ℃ Electrical Characteristics(TA=25 oC, unless otherwise noted) Parameter Symbol Collector cut-off current Emitter cut-off current BC807/BC808-16 BC807/BC808-25 DC current gain BC807/BC808-40 Collector-emitter saturation voltage Base-emitter saturation voltage Transition frequency Collector Base Capacitance ICBO IEBO hFE1 hFE2 hFE3 hFE4 VCE(sat) VBE(on) fT Ccbo Test conditions Min Typ VCB =-20V VEB =-5V 100 160 250 VCE =-1V, IC =-100mA VCE =-1V, IC =-500mA IC =-500mA, IB =-50mA IC =-500mA,VCE =-1V 40 VCE=-5V,IC=-10mA, f=50MHz 80 VCB=-10V, f=1MHz Max Unit -100 -100 250 400 600 nA nA -0.7 -1.2 V V MHZ pF 9 Marking RANK Marking RANK Marking BC807-16 BC807-25 BC807-40 5CR 5CS 5CT BC808-16 BC808-25 BC808-40 5CW 5CX 5CY AGERTECH MICROELECTRONICS Subsidiary of Sino-Talent International Holdings Ltd. 1/3 Dated:12/2020 Rev: 1.0 BC807/BC808-16/-25/-40 Typical Characteristics Curves AGERTECH MICROELECTRONICS Subsidiary of Sino-Talent International Holdings Ltd. 2/3 Dated:12/2020 Rev: 1.0 BC807/BC808-16/-25/-40 Package Outline e ∠ALL ROUND A D e M e E C a L1 L HE SOT-23 mechanical data UNIT mm mil A C D E HE max 1.1 0.15 1.4 3.0 2.6 min 0.9 0.08 1.2 2.8 2.2 max 43 6 55 min 35 3 47 e M L L1 a 0.5 1.95 0.55 (ref) 0.3 1.7 0.36 (ref) 0.15 118 102 20 77 6 110 12 67 14 (ref) 87 22 (ref) ∠ 0.0 0.0 12° The recommended mounting pad size AGERTECH MICROELECTRONICS Subsidiary of Sino-Talent International Holdings Ltd. 3/3 Dated:12/2020 Rev: 1.0
BC807-40 价格&库存
很抱歉,暂时无法提供与“BC807-40”相匹配的价格&库存,您可以联系我们找货
