1N4001FL
1N4001FL
    AGERTECH(艾吉芯)
    SMF(SOD-123FL)
    1N4001FL
1N4001FL 数据手册
1N4001FL THRU 1N4007FL SURFACE MOUNT GENERAL PURPOSE SILICON RECTIFIERS Forward current-1.0A Reverse voltage-50V to1000V FEATURES  For surface mount applications  Glass passivated chip junction  Low profile package  Ideal for automated placement  Lead free in comply with EU RoHS 2011/65/EU diretives PINNING PIN DESCRIPTION 1 Cathode 2 Anode MECHANICAL DATA 1  Case:SOD-123FL molded plastic body  Terminals:Solderable per MIL-STD-750,Method 2026  Weight: : Approximated 0.015 grams 2 Top View Simplified outline SOD-123FL and symbol MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derating by 20 % PARAMETER SYMBOL 1N4001FL 1N4002FL 1N4003FL 1N4004FL 1N4005FL 1N4006FL 1N4007FL UNIT Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TC=125℃ IF(AV) 1 A Peak Forward Surge Current (Note1) IFSM 30 A Maximum Forward Voltage at 1.0A VF 1.1 V Maximum DC Reverse Current at Rated DC Blocking Voltage TA=25℃ IR 5 50 uA CJ 11 pF RθJA 90 ℃/W TJ,TSTG -55 to +150 ℃ TA=125℃ Junction Capacitance (Note2) Thermal Resistance (Note3) Operating and Storage Temperature Range Notes: 1. Measured at 8.3 ms single half sine wave superimposed on rated load (JEDEC Method) . 2. Measured at 1MHz and applied reverse voltage of 4.0 D.C. 3. P.C.B.mounted with 2.0 " × 2.0 " (5×5 cm) copper pad areas. AGERTECH MICROELECTRONICS  Subsidiary of Sino-Talent International Holdings Ltd.  1 / 3  Dated: 04/2016  Rev:1.0  1N4001FL THRU 1N4007FL RATINGS AND CHARACTERISTIC CURVES AGERTECH MICROELECTRONICS  Subsidiary of Sino-Talent International Holdings Ltd.  2 / 3  Dated: 04/2016  Rev:1.0  1N4001FL THRU 1N4007FL PACKAGE OUTLINE SOD-123FL 2.60 2.90 1.70 1.90 0.80 1.10 Top View 0.12 0.20 0.90 1.10 0.70 0.90 Bottom View 3.50 3.80 Dimensions in milimeters ORDERING INFORMATION Device Package Shipping 1N4001FL thru 1N4007FL SOD-123FL 3,000/Tape & Reel (7 inches) AGERTECH MICROELECTRONICS  Subsidiary of Sino-Talent International Holdings Ltd.  3 / 3  Dated: 04/2016  Rev:1.0
1N4001FL
物料型号:1N4001FL至1N4007FL
器件简介: - 这些是用于表面安装的通用硅整流器。 - 正向电流为1.0A,反向电压从50V到1000V不等。 - 具有玻璃钝化芯片结和低轮廓封装,适合自动化安装。 - 符合欧盟RoHS 2011/65/EU指令的无铅。
引脚分配: - 引脚1:阴极 - 引脚2:阳极
参数特性: - 最大重复峰值反向电压(VRRM):50V至1000V - 最大RMS电压(VRMS):35V至700V - 最大直流阻断电压(Voc):50V至1000V - 最大平均正向整流电流在125°C时(IF(AV)):1A - 峰值正向浪涌电流(IFsM):30A - 最大正向电压在1.0A时(VF):1.1V - 额定直流阻断电压下的最大直流反向电流在25°C时(IR):5uA至50uA - 结电容(CJ):11pF - 热阻(ReJA):90°C/W - 工作和存储温度范围(T,TstG):-55至+150°C
功能详解: - 这些整流器适用于单相半波60Hz的电阻性或感性负载,对于电容性负载,电流需要降低20%。 - 提供了正向电流降额曲线、典型瞬态反向特性、典型正向特性、典型结电容和最大非重复峰值正向浪涌电流的图表。
应用信息: - 这些整流器适用于需要表面安装的场合。
封装信息: - 封装类型:SOD-123FL模塑塑料体 - 引脚:可焊接,符合MIL-STD-750,方法2026 - 重量:大约0.015克 - 封装尺寸:2.60 x 2.90 mm(顶部视图),1.70 x 1.90 mm(底部视图),0.80 x 1.10 mm(引脚间距)
订购信息: - 器件型号:1N4001FL至1N4007FL - 封装:SOD-123FL - 包装:3000/卷带(7英寸)
1N4001FL 价格&库存
很抱歉,暂时无法提供与“1N4001FL”相匹配的价格&库存,您可以联系我们找货
