ATM2312NSA
N-CHANNEL ENHANCEMENT MODE POWER MOSFET
Drain-Source Voltage: 20V
Continuous Drain Current: 5.0A
FEATURES
Small Package:SOT-23
VDS=20V, ID=5A
SOT-23
RDS(ON)≤ 31.8mΩ@VGS=4.5V
RDS(ON)≤35.6mΩ@VGS=2.5V
Advanced Trench Technology
APPLICATIONS
D
Load Switching for portable Application
DC/DC Converter
3
1
G
2
S
Schematic diagram
ABSOLUTE MAXIMUM RATINGS
(TA=25℃, unless otherwise noted)
Parameter
Symbol
Value
Unit
VDS
V
Gate-Source Voltage
VGS
±8.0
V
ID
5
Pulsed Drain Current
IDM
Continuous Source-Drain Diode Current
IS
1.04
PD
0.35
W
RθJA
357
℃/W
TJ
150
TSTG
-55 to 150
t = 5s
Maximum Power Dissipation
t = 5s
Junction-to-Ambient Thermal Resistance
Junction Temperature
Storage Temperature Range
AGERTECH MICROELECTRONICS
Subsidiary of Sino-Talent International Holdings Ltd.
1/6
A
Dated: 07/2017
Rev:2.0
ATM2312NSA
ELECTRICAL CHARACTERISTICS
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
V(BR)DSS
VGS = 0V, ID = 250μA
V
Gate Threshold Voltage
VGS(th)
VDS = VGS, ID = 250μA
0.45
0.7
1.0
V
Gate Leakage Current
IGSS
VDS = 0V, VGS = ±8V
±100
nA
Zero Gate Voltage Drain Current
IDSS
VDS =20V, VGS = 0V
1
μA
VGS = 4.5V, ID = 5.0A
18
31.8
23
35.6
Static
Drain-Source On-ResistanceNote1
Forward transconductance
RDS(ON)
VGS = 2.5V, ID = 4.7A
VGS = 1.8V, ID = 4.3A
30
41.4
VDS = 10V, ID = 5.0A
6
865
105
55
0.5
4.8
10
12
0.75
1.2
gfs
mΩ
S
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Gate Resistance
Rg
Turn-On Delay Time
td(on)
Turn-On Rise Time
tr
VDS = 10V,
VGS = 0V,
f = 1MHz
f=1MHz
VDD = 10V, RL = 2.2Ω
RG = 1Ω, VGEN = 5V
Turn-Off Delay Time
Turn-Off Fall Time
td(off)
ID = 4A
tf
pF
Ω
ns
Drain-source Body Diode
Forward Diode Voltage
VSD
VGS = 0V, IS = 4A
V
Notes:1. Pulse test: pulse width ≦ 300us, duty cycle≦ 2%.
2/6
Dated: 07/2017
Rev:2.0
ATM2312NSA
RATINGS AND CHARACTERISTIC CURVES
Threshold Voltage
3/6
Dated: 07/2017
Rev:2.0
ATM2312NSA
PACKAGE OUTLINE
SOT-23
0.8
Max.
1.025
1.150
A1
0.000
0.050
0.100
b
c
D
0.300
0.080
2.800
0.400
0.115
2.900
0.500
0.150
3.000
E
1.200
1.300
1.400
HE
2.250
2.400
2.550
e
1.800
1.900
2.000
0.8
1.9
SOT-23
0.550REF
L1
2.2
Typ.
0.900
A
1.0
Dimensions in millimeter
Min.
1.0
Symbol
L
0.300
0.500
θ
0o
8o
Recommended soldering pad
ORDERING INFORMATION
Device
ATM2312NSA
Package
SOT-23
4/6
Shipping
3000/Reel&Tape(7inch)
Dated: 07/2017
Rev:2.0
ATM2312NSA
CONDITIONS OF SOLDERING AND STORAGE
Recommended condition of reflow soldering
Recommended peak temperature is over 245℃. If peak temperature is below 245℃, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370℃
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40℃
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/6
Dated: 07/2017
Rev:2.0
ATM2312NSA
PACKAGE SPECIFICATIONS
The method of packaging
SOT-23 (TO-236)
3,000 pcs per reel
1
3
2
30,000 pcs per box
10 reels per box
220
195
43
5
120,000 pcs per carton
4 boxes per carton
435
210
Embossed tape and reel data
T
G
4.0
4.0
F
N
B
H
8.0
E
D
120°±2°
1Pin
C
A
Tape (8mm)
Symbol
A
B
C
E
F
D
G
H
N
T
Reel (7'')
6/6
Value (unit: mm)
3.15 ± 0.1
2.7 ± 0.1
1.25 ± 0.1
2 ± 0.5
13 ± 0.5
178 ± 2.0
8.4 ± 1.5
4 ± 0.5
60
< 14.9
Dated:07/2017
Rev: 2.0
很抱歉,暂时无法提供与“ATM2312NSA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14321
- 200+0.11060
- 600+0.09245
- 3000+0.08414
- 9000+0.07463
- 21000+0.06956
