BC817-16/-25/-40
NPN Transistor
Features
For switching, AF driver and amplifier applications
These transistors are subdivided into three groups
SOT-23
-16, -25 and -40, according to their current gain. As
complementary types the PNP transistors BC817 are
recommended
1 Base 2. Emitter 3. Collector
Absolute Maximum Ratings (TA=25℃, unless otherwise noted)
Parameter
Collector Base Voltage
Collector Emitter Voltage
Emitter Base Voltage
Collector Current
Power Dissipation
Operation Junction and Storage Temperature Range
Symbol
Value
Unit
VCBO
VCEO
VEBO
IC
PC
TJ,TSTG
50
45
5
0.5
0.3
150,-55 to 150
V
V
V
A
W
Electrical Characteristics(TA=25 oC, unless otherwise noted)
Parameter
Symbol
Collector cut-off current
Emitter cut-off current
DC current gain
BC817-16
BC817-25
BC817-40
Collector-emitter saturation voltage
Base-emitter saturation voltage
Transition frequency
Collector Base Capacitance
ICBO
IEBO
hFE1
hFE2
hFE3
hFE4
VCE(sat)
VBE(on)
fT
Cbo
Test conditions
Min
Typ
VCB =20V
VEB =5V
100
160
250
VCE =1V, IC =100mA
VCE =1V, IC =500mA
IC =500mA, IB =50mA
IC =500mA,VCE =1V
40
VCE=5V,IC=10mA, f=50MHz
100
Max
Unit
100
100
250
400
600
nA
nA
0.7
1.2
V
V
MHZ
9
VCB=10V, f=1MHz
pF
Marking
RANK
Marking
BC817-16
BC817-25
BC817-40
6CQ
6CS
6CT
AGERTECH MICROELECTRONICS
Subsidiary of Sino-Talent International Holdings Ltd.
1/3
Dated:12/2020
Rev: 1.0
BC817-16/-25/-40
Typical Characteristics Curves
2/3
Dated:12/2020
Rev: 1.0
BC817-16/-25/-40
Package Outline
3/3
Dated:12/2020
Rev: 1.0
很抱歉,暂时无法提供与“BC817-40”相匹配的价格&库存,您可以联系我们找货
