ATM1205PSI
P-Channel Enhancement Mode Field Effect Transistor
Description
Feature
The ATM1205PSI uses advanced trench technology
VDS (V) = -12V
to provide excellent RDS(ON), low gate charge and
ID = -1.7 A (VGS = -4.5V)
operation with gate voltages as low as 1.8V. This
RDS(ON) < 100mΩ (VGS = -4.5V)
device is suitable for use as a load switch or in
RDS(ON) < 130mΩ (VGS = -3.6V)
PWM applications. Standard Product ATM1205PSI
RDS(ON) < 150mΩ (VGS = -2.5V)
is Pb-free.
RDS(ON) < 250mΩ (VGS = -1.8V)
SOT-323
Marking
D
B
YW
BYW
D
G
Device code
Date code
G
Order Information
S
S
Top View
Schematic
Device
Package
Shipping
ATM1205PSI
SOT-323
3000/Tape&Reel
Absolute Maximum Ratings (TA=25oC, unless otherwise noted)
Parameter
Symbol
Maximum
Units
Drain-Source Voltage
VDS
-12
V
Gate-Source Voltage
VGS
±12
V
Continuous Drain Current
TA=25°C
NOET 1
TA=70°C
Pulsed Drain Current NOET 2
-1.7
ID
IDM
TA=25°C
Power Dissipation NOET 1
TA=70°C
Junction and Storage Temperature Range
A
-1.4
-20
A
0.47
PD
W
0.30
TJ, TSTG
-55 to 150
°C
Thermal Characteristics
Parameter
Symbol
Maximum Junction-to-Ambient
NOET 1
NOET 1
Maximum Junction-to-Lead
NOET 3
t≤ 10s
Steady-State
Steady-State
RθJA
RθJL
Typ
Max
Units
215
265
°C/W
240
300
°C/W
105
130
°C/W
AGERTECH MICROELECTRONICS
Subsidiary of Sino-Talent International Holdings Ltd.
1/5
Dated:10/2019
Rev: 1.0
ATM1205PSI
Electrical Characteristics (TA=25°C unless otherwise noted)
Parameter
Static Characteristics
Symbol
Conditions
Drain-Source Breakdown Voltage
BVDSS
ID=-250µA, VGS=0V
Zero Gate Voltage Drain Current
IDSS
VDS=-9.6V, VGS=0V
-1
µA
Gate-Body leakage current
IGSS
VDS=0V, VGS=±12V
±100
nA
VGS(th)
VDS=VGS, ID=-250µA
-0.75
-1.0
V
VGS=-4.5V, ID=-1.7A
75
100
mΩ
VGS=-3.6V, ID=-1.0A
80
130
mΩ
VGS=-2.5V, ID=-1.0A
103
150
mΩ
250
mΩ
Gate Threshold Voltage
Static Drain-Source On-Resistance
RDS(ON)
Min
Typ
Max
Units
-12
-0.45
V
VGS=-1.8V, ID=-0.6A
150
Forward Transconductance
gFS
VDS=-1.8V, ID=-1.0A
4.8
Diode Forward Voltage
VSD
IS=-1.0A,VGS=0V
-0.85
S
-1.2
V
Dynamic Characteristics
Input Capacitance
Output Capacitance
Reverse Transfer Capacitance
Ciss
618
pF
Coss
VGS=0V, VDS=-10V,
172
pF
Crss
f=100KHz
134
pF
8.7
nC
1.5
nC
Switching Characteristics
Total Gate Charge
Qgtot
Qgs
VGS=-4.5V, VDS=-10V,
Gate Drain Charge
Qgd
ID=-1.7A
Turn-On Delay Time
td(on)
Turn-On Rise Time
tr
Turn-Off Delay Time
td(off)
Gate Source Charge
Turn-Off Fall Time
VGS=-4.5V, VDD=-10V,
Id=-1.7A, RGEN=6Ω
tf
2.9
nC
15.8
ns
19.8
ns
92.4
ns
139.6
ns
Note:
1.
The value of RθJA is measured with the device mounted on 1in 2 FR-4 board with 2oz. Copper, in a still air environment withTA
=25°C. The value in any given application depends on the user's specific board design. The current rating is based on the t ≤
10s thermal resistance rating.
2.
Repetitive rating, pulse width limited by junction temperature.
3.
The RθJA is the sum of the thermal impedence from junction to lead R θJL and lead to ambient.
4.
The static characteristics in Figures 1 to 6 are obtained using 80 µs pulses, duty cycle 0.5% max.
5.
These tests are performed with the device mounted on 1 in2 FR-4 board with 2oz. Copper, in a still air environment with
TA=25°C. The SOA curve provides a single pulserating.
2/5
Dated:10/2019
Rev: 1.0
ATM1205PSI
RATINGS AND CHARACTERISTIC CURVES
Fig 1: On-Region Characteristics
Figure 2: Transfer Characteristics
Figure 3: On-Resistance vs. Drain Current and
Figure 4: On-Resistance vs. Junction
Gate Voltage
Temperature
Figure 5: On-Resistance vs Gate-Source
Figure 6: Body-Diode Characteristics
3/5
Dated:10/2019
Rev: 1.0
ATM1205PSI
Figure 7: Gate-Charge Characteristics
Figure 8: Capacitance Characteristics
Figure 9: Maximum Forward Biased Safe
Figure 10: Single Pulse Power Rating
Operating Area (Note 5)
Junction-to-Ambient (Note 5)
PD
T on
T
1. DutyCycle, D=Ton/T
2. Per
Unit Base=RθJA =300oC/W
3.TJ,Max-TA=PDM*ZθJA*RθJA
Figure 11: Normalized Maximum Transient Thermal Impedance
4/5
Dated:10/2019
Rev: 1.0
ATM1205PSI
Package Outline Dimension (Units: mm)
SOT-323
Recommended Soldering Footprint
1.6
0.8
0.8
0.8
0.8
1.3
Packing information
Package
SOT-323
Pitch
Reel Size
Tape Width
(mm)
mm
inch
mm
inch
8
4 ± 0.1
0.157 ± 0.004
178
7
Per Reel Packing Quantity
5/5
3,000
Dated:10/2019
Rev: 1.0
很抱歉,暂时无法提供与“ATM1205PSI”相匹配的价格&库存,您可以联系我们找货
