1N4007FL
1N4007FL
    AGERTECH(艾吉芯)
    SMF(SOD-123FL)
    1KV 1A
1N4007FL 数据手册
1N4001FL THRU 1N4007FL SURFACE MOUNT GENERAL PURPOSE SILICON RECTIFIERS Forward current-1.0A Reverse voltage-50V to1000V FEATURES  For surface mount applications  Glass passivated chip junction  Low profile package  Ideal for automated placement  Lead free in comply with EU RoHS 2011/65/EU diretives PINNING PIN DESCRIPTION 1 Cathode 2 Anode MECHANICAL DATA 1  Case:SOD-123FL molded plastic body  Terminals:Solderable per MIL-STD-750,Method 2026  Weight: : Approximated 0.015 grams 2 Top View Simplified outline SOD-123FL and symbol MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derating by 20 % PARAMETER SYMBOL 1N4001FL 1N4002FL 1N4003FL 1N4004FL 1N4005FL 1N4006FL 1N4007FL UNIT Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TC=125℃ IF(AV) 1 A Peak Forward Surge Current (Note1) IFSM 30 A Maximum Forward Voltage at 1.0A VF 1.1 V Maximum DC Reverse Current at Rated DC Blocking Voltage TA=25℃ IR 5 50 uA CJ 11 pF RθJA 90 ℃/W TJ,TSTG -55 to +150 ℃ TA=125℃ Junction Capacitance (Note2) Thermal Resistance (Note3) Operating and Storage Temperature Range Notes: 1. Measured at 8.3 ms single half sine wave superimposed on rated load (JEDEC Method) . 2. Measured at 1MHz and applied reverse voltage of 4.0 D.C. 3. P.C.B.mounted with 2.0 " × 2.0 " (5×5 cm) copper pad areas. AGERTECH MICROELECTRONICS  Subsidiary of Sino-Talent International Holdings Ltd.  1 / 3  Dated: 04/2016  Rev:1.0  1N4001FL THRU 1N4007FL RATINGS AND CHARACTERISTIC CURVES AGERTECH MICROELECTRONICS  Subsidiary of Sino-Talent International Holdings Ltd.  2 / 3  Dated: 04/2016  Rev:1.0  1N4001FL THRU 1N4007FL PACKAGE OUTLINE SOD-123FL 2.60 2.90 1.70 1.90 0.80 1.10 Top View 0.12 0.20 0.90 1.10 0.70 0.90 Bottom View 3.50 3.80 Dimensions in milimeters ORDERING INFORMATION Device Package Shipping 1N4001FL thru 1N4007FL SOD-123FL 3,000/Tape & Reel (7 inches) AGERTECH MICROELECTRONICS  Subsidiary of Sino-Talent International Holdings Ltd.  3 / 3  Dated: 04/2016  Rev:1.0
1N4007FL 价格&库存
很抱歉,暂时无法提供与“1N4007FL”相匹配的价格&库存,您可以联系我们找货
1N4007FL
库存:9108
1N4007FL
    • 1+0.18700
    • 200+0.06215
    • 1500+0.03883
    • 3000+0.03080
    库存:9108
