ESD3C15V01V
ESD3C15V01V
    JF(晶发)
    SOD-323
    ESD3C15V01V
ESD3C15V01V 数据手册
R ESD3C15V01V Transient Voltage Suppression Diode S E M I C O N D U C T O R Features ■ 320Watts peak pulse power (tp = 8/20μs) ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 10A (8/20μs) Applications Mechanical Data ■ Microprocessor based equipment ■ Personal Digital Assistants (PDA’s) SOD323 package ■ ■ Notebooks, Desktops, and Servers Molding compound flammability rating: UL 94V-0 ■ ■ ■ Portable Instrumentation Packaging: Tape and Reel Pagers Peripherals  RoHS/WEEE Compliant ■ Schematic & PIN Configuration SOD-323 JINAN JINGHENG ELECTRONICS CO., LTD. 4-1 HTTP://WWW.JINGHENG.CN ESD3C15V01V Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 320 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 10 A VESD 20 15 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM VBR IT=1mA Reverse Leakage Current IR VRWM=15V,T=25℃ Clamping Voltage VC Junction Capacitance Cj Max Units 15.0 V V 16.7 IPP=10A,tp=8/20μs VR = 0V, f = 1MHz 0.5 uA 32 V 20 pF Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I IPP Working Peak Reverse Voltage VC VBR VRWM Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT IR IR IT VRWM VBR VC Test Current IPP Note:. 8/20μs pulse waveform. JINAN JINGHENG ELECTRONICS CO., LTD. 4-2 HTTP://WWW.JINGHENG.CN V ESD3C15V01V Typical Characteristics Figure 2: Power Derating Curve 10 110 320w8/20 μs waveform 1 0.1 0.01 0.1 1 10 100 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 100 90 80 70 60 50 40 30 20 10 0 1,000 0 25 td – Pulse Duration - µs Figure3: Pulse Waveform Percent Ipp 80 80 Clamping Voltage–VC (V) 90 e-1 50 40 30 td=Ipp/2 20 10 0 0 100 125 150 90 Waveform Paramters tr=8µs td=20µs 100 60 75 Figure 4: Clamping Voltage vs.Ipp 110 70 50 Ambient Temperature - TA (℃) Test Waveform Paramters tr=8µs td=20µs 70 60 50 40 30 20 10 5 10 15 20 25 30 0 0 Time (µs) JINAN JINGHENG ELECTRONICS CO., LTD. 2 4 6 8 10 Peak Pulse Current–IPP (A) 4-3 HTTP://WWW.JINGHENG.CN 12 ESD3C15V01V Outline Drawing – SOD323 C A DIMENSIONS SYMBOL E B 1 2 MILLIMETER MIN MAX MIN MAX A 1.600 1.800 0.063 0.071 B 0.250 0.350 0.010 0.014 C 2.500 2.700 0.098 D D H L 1.000 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 0.475 REF 0.019REF L1 0.250 0.400 0.010 0.016 H 0.000 0.100 0.000 0.004 L1 Marking 1 15B 2 Ordering information Order code ESD3C15V01V Package SOD323 JINAN JINGHENG ELECTRONICS CO., LTD. Base qty 3000 4-4 0.106 0.039 E L F INCHES Delivery mode Tape and reel HTTP://WWW.JINGHENG.CN
ESD3C15V01V 价格&库存
很抱歉,暂时无法提供与“ESD3C15V01V”相匹配的价格&库存,您可以联系我们找货
