2N7002DW-7-F-ES
2N7002DW-7-F-ES
    ELECSUPER(静芯微)
    SOT-363
    2N7002DW-7-F-ES
2N7002DW-7-F-ES 数据手册
2N7002DW-7-F-ES Rev-1.1 www.elecsuper.com SuperMOS – SOT363 60V BVDSS 1.5Ω RDS(on) 0.38A ID, N-channel MOSFET 1. Description The 2N7002DW-7-F-ES is N-Channel enhancement MOS Field Effect Transistor. Uses advanced trench technology and design to provide excellent RDS(ON) with low gate charge. Device is suitable for use in DC-DC conversion, power switch and charging circuit. Standard Product 2N7002DW-7-F-ES is Pb-free. 2. Features  60V, RDS(ON)=1.5Ω(Typ), VGS=10V  Material: Halogen free RDS(ON)=2.4Ω(Typ), VGS=4.5V  Reliable and rugged  Use trench MOSFET technology  Avalanche Rated  High density cell design for low RDS(on)  Low leakage current 3. Applications  PWM applications  Power management in portable/desktop PCs  Load switch  DC/DC conversion 4. Ordering Information Part Number 2N7002DW-7F-ES Package Marking Material Packing Quantity per reel Flammability Rating SOT363 Halogen free Tape & Reel 3,000 PCS UL 94V-0 72KZ Table-1 Reel Size 7 inches Ordering information 5. Pin Configuration and Functions Pin Function 1 Source1 2 Gate1 6 Drain1 4 Source2 5 Gate2 3 Drain2 Copyright© ElecSuper Incorporated Outline 6 5 4 Circuit Diagram D1 G2 5 6 S2 4 72KZ 1 2 3 Contact Us 1 S1 2 G1 3 D2 1 / 7 2N7002DW-7-F-ES Rev-1.1 Table-2 www.elecsuper.com Pin configuration 6. Specification Absolute Maximum Rating & Thermal Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Parameter Symbol Limit Unit Drain-Source Voltage BVDSS 60 V Gate-Source Voltage VGS ±20 V TA=25℃ Continuous Drain Current TA=100℃ 0.38 ID A 0.25 Maximum Power Dissipation PD 350 mW Pulsed Drain Current a IDM 1.5 A Operating Junction Temperature TJ 150 °C Lead Temperature TL 260 °C Storage Temperature Range Tstg -55 to 150 °C Thermal resistance ratings Single Operation Parameter Junction-to-Ambient Thermal Resistance Symbol Typical Unit RθJA 300 °C/W Note: a: Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1% Copyright© ElecSuper Incorporated Contact Us 2 / 7 2N7002DW-7-F-ES Rev-1.1 www.elecsuper.com Electrical Characteristics At TA = 25℃ unless otherwise specified Parameter Symbol Test Conditions Min. Typ. Max. Unit OFF CHARACTERISTICS Drain-to-Source Breakdown Voltage BVDSS VGS=0V, ID=10mA 60 V Zero Gate Voltage Drain Current IDSS VDS=60V, VGS=0V 1.0 uA Gate-to-source Leakage Current IGSS VDS=0V, VGS=±20V ±10 uA Forward Trans conductance gfs VDS=10V, ID=0.1A 0.24 S ON CHARACTERISTICS Gate Threshold Voltage VGS(TH) Drain-to-source On-resistance RDS(on) VGS=VDS, ID=250uA 1.1 1.5 2.4 VGS=10V, ID=0.3A 1.5 3 VGS=4.5V, ID=0.2A 2.4 3.7 30.5 45 5.5 10 V Ω CHARGES, CAPACITANCES AND GATE RESISTANCE Input Capacitance CISS VGS=0V, f=1MHz, VDS =10V Output Capacitance COSS Reverse Transfer Capacitance CRSS 4.1 8 QG(TOT) 1.12 2 0.1 0.2 0.23 0.5 3 6 5 10 14 27 9 17 Total Gate Charge Gate-to-Source Charge QGS Gate-to-Drain Charge QGD VGS=10V, VDS=30V, ID=0.2A pF nC SWITCHING CHARACTERISTICS Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time td(ON) tr td(OFF) VGS=10V, VDS=30V, ID=0.2A, RG=6Ω tf ns BODY DIODE CHARACTERISTICS Forward Voltage Copyright© ElecSuper Incorporated VSD VGS=0V, IS=1A Contact Us 1 V 3 / 7 2N7002DW-7-F-ES Rev-1.1 www.elecsuper.com 7. Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 4 / 7 2N7002DW-7-F-ES Copyright© ElecSuper Incorporated Rev-1.1 Contact Us www.elecsuper.com 5 / 7 2N7002DW-7-F-ES Rev-1.1 www.elecsuper.com 8. Dimension and Patterns (SOT363) Unit: mm Symbol Spec A A1 A2 b c D θ Min 0.900 0.000 0.900 0.150 0.080 2.000 0° Max 1.100 0.100 1.000 0.350 0.150 2.200 8° E E1 e e1 L L1 - Min 1.150 2.150 1.200 - 1.350 2.450 0.525 REF 0.2600 Max 0.650 REF 0.4600 - Symbol Spec Copyright© ElecSuper Incorporated Contact Us 1.400 6 / 7 2N7002DW-7-F-ES Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
2N7002DW-7-F-ES 价格&库存
很抱歉,暂时无法提供与“2N7002DW-7-F-ES”相匹配的价格&库存,您可以联系我们找货
